Awesome review HKJ, thanks!
Would you say this is the best universal Li-Ni battery charger out there for the money?
I have only tested the i4 V1 and V2, no other universal chargers, this makes it impossible to say if it is the best.
But it is good value for the money.
The one major downside of these units is the stiffness of the spring negative arm. I've done finger nails trying to get these apart and get a battery in. I've heard some 18650s are coming out with a foil like bottom instead of a metal plate. I'd steer these away from the i4. They could, if your not careful, wreak the foil.
:D
Group Purchase, I am in.
So can someone clearly explain what it going on with charge currents and slots? Lithium-Ion for example (although it seems nearly identical for NiMh except for voltage). Seems from the graph that it's charging at 750mA (until end of charge - just ignore the end for my explanation). Is this 750mA per each of 4 slots? In other words with all 4 slots loaded each cell gets 750mA charge rate? Or (as it sounds to me) that 750mA gets split in half and divided between the channels (channel 1 being slots 1&3 and channel 2 being slots 2&4 - so with 4 cells loaded, they'd each be charging at 375mA? So if I'd want to charge two cells at 750mA I'd have to load a cell into slot 1 (channel 1) and then use slot 2 or 4 so I have the second cell on channel 2? If I'd load 3 cells in using slots 1,2,&3 than the cells in slots 1&3 will charge at 375mA and the cell in slot 2 will charge at 750mA? Am I correct in my understanding?
This does sound like a nice universal charger. I only wish the charge rate were higher for 26650 cells.
-Garry
The green text is basically correct. Basically because the current is still 750mA, but only half the time, with LiIon this makes the charge time slightly longer, compared to a real 375 mA charger.
It is not the fastest charger around, if you look at the text under the chart with 4 batteries, it says 11 hours.
How much is the group purchase for??????
This charger will fully charge my 16340's, 14500's and 18650's quickly to 4.22v
I like to use this versus a hobby charger, its just quick and easy.
Its a pitty that DD cant offer any group buys anymore, except for regular coupon coudes
HKJ, thank you very much for clarifications!
Tempted to buy this charger even tho I dont use Li batteries at all, but seeing this priced at less than 25$ is rather big temptation to pull the trigger on universal charger :D!
One question to add, sorry for spamming this thread
Can I add some conductive piece of metal between + on charger and + on cell and charge D sized batteries?
Will it stop when they are full at for example 8000mAh or 10'000mAh or will it stop at 5000mAh because that is the currently highest 26650 capacity available and charger might not recognise higher cell capacity as safe?
Well mine just charged my 18650s to 4.27 volts. Luckily nothing happened since men are supposed to be charged to 4.35. So I’m not sure I would trust.
If you lube it when you first get it, it's not a problem. I lubed mine with the same lube I use on my orings. Once you dou that it's smooth as butter.
If you don't lube it, and you force it, it's pretty much wrecked as the metal slides will bite into the plastic and chip it up.
This is a really nice charger for the King.
Ok, another one:
So, basically, it charges at 750mA current in all slots, only thing worth noting is that its charging in pulses and not constantly? Or does it really drops the output to real 350mA in those two other slots and it has nothing to do with pulse charging and its real 2x750mA and 2x350mA=4slots?
All this got me confused somehow, exactly when it seemed perfectly clear :D!
Ok, another one:
750mA all the time and with pulses.
Thank you!
actually i think this is the BEST charger for the king !!!
Simple solution sir . Apply some silicone grease with a tiny paint brush inside the sliding plastic slot and itl be smooth as can be!!!
Your picture didn't work. :P
