Lumintop and Klarus are CC ;)
You are right my numbers were wrong (thanks to the use of a too long/thin wire)
With a shorter wire I also get 1,6 to 1,7A on high with a nimh
It's supposed to be CC so no pwm. Anyone got an E09 from DD with no pwm?
please could you guys take a photo of the setup? i might be getting a kickass digital multimeter but i wouldnt know how you connect/wire the E09 head with the multimeter and with the battery.
i mean.. the head of the E09 is so tiny!! Are you using magnets at the tip of the wire?
Please some photos, i need to see how ampere measurements on AAA (and AA) flashlights are done! Thanks for some help here!!
Just a little note, DD has raised the price on it ONCE AGAIN, yesterday it was 12.99, today already 13.99, although 12.99 should have run for another 4-6 days according to their offer timer near the price, wtf ?!
I guess no matter how good this thing turns out to be Ill have to wait for some discounts in the future, no way I am buying this for more than initially advertised price that you guys snatched this one for.
Me too.
Me and my friend managed to place one order and were planning on getting more. Too late now. With reports of pwm when it is supposed to be CC, I think I'll just spend a little bit more and get a better light.
If I were you, that's what I'd be doing. To be fair though, I originally bought an E09 from MF for $14 and change and I feel it's still a good value even at that price. That's why I ordered a couple more from DD when they could be had for cheap.
As for the timer, it's best to just ignore it. ;)
Hi
One big question.
Why should i use a copper spacer? Whats the use of it?
The lights work anyway, don't they?
barnefko, the review isnt finished yet. once it is, you'll know why!! haha
( yes, the light works also without aluminum/copper sealing washer. )
Have you determined how best to disassemble it? Does the head seem to be two pieces?
I was hoping that might be a seam at the edge of the knurling. Mine hasn't arrived from DD yet.
OP updated ;) -- the review is still in progress. my Eneloops havent charged yet..
The reflector is so tiny! I mean not deep at all
Guys, DO NOT DISASSEMBLE THE HEAD. the alu reflector causes a short on the LED pill.
originally the reflector is "glued" to the LED dome. The glue is the insulating layer so that the aluminum of the reflector cannot bridge (short) the contacts of the PCB.
Any idea how i can insulate now??
Why am i asking?
Effectively, both of my samples have stopped working. They still work in mule mode, i.e. with reflector head off. As soon as i screw on the reflector head, light off.
apply glue
wont it melt with the high temperatures of 10440's? :D
Depending which glue you use.... maybe superglue3 will be not the best idea.
Why am i asking?
Truly big thanks for taking the hit for the team (apparently both barrels). I will follow your advice and will not disassemble the head on mine. Hope you find a way to re-insulate.
thanks for thanking haha.
i just run the lights now without lens and without reflector (and without lens o-ring). kinda Fenix E01 style-like!!
:D
Do you have access to printable transparent laser overhead foils? Your next copy shop should have one for cheap. It's thermally strong and shouldn't conduct electricity. They make great LED washer in a pickle.
Awesome! Thanks kreisler. So happy it disassembles!
Kapton (polyimide) tape, its designed for this. Non-conductive. Also called just Heat resistant/High temperature tape on DX / chinese sites. Used on PCBs everywhere & in protected batteries to insulate the wire along the side that leads to positive. Kapton on a 18650.
Would be faster to pick up those transparencies for laser printers then waiting for kapton in the mail.
Just in case, don't use any superglue (cyanoacrylate) near leds/optics, the fumes will cloud it.
okay, thanks for the suggestions. my idea was to use Scotch tape (tesa movie haha) but since i had some transparent book foil flying around i tried that first. And it works!! Now both of my E09's work again, and i can tighten the upper head part as strong as i want to!!!
My very first idea was a combination of Tipp-Ex (for the sides of the mini PCB) and a circular cut adhesive foil ("foil ring") to fit into the reflector seam, and the Tipp-Ex works really good at the sides as expected. But it's easier and more straight-forward to drop the Tipp-Ex completely and cut out a larger square from the adhesive foil with a hole in the middle and fit it over the LED dome.
The cut out square should be anywhere between 5x5mm² and 6x6mm². The green mini PCB's size is 3.5x3.5mm².
Verdict:
Now knowing and understanding what can go wrong with the E09 (when you take out the rear spring, when you screw off the upper head part and rip off the reflector from the PCB) and that it is easy to exchange o-rings, lenses, reflectors, i am growing fond of this little serial-numbered thing even more.
It's unlikely that the lens would ever break with normal usage and drops. If the E09 is attached to your keychain or keyrings and you let it drop, the lens will not break, i am sure.
And if the light doesnt turn on anymore, then we know already why: it's because of the rear spring (if you've ever taken it out before. otherwise not.) or because of a short (short circuit) due to the compromised insulation, as described. Then you fix the insulation, as described, and your light is back on.
The head is massive aluminum .. great as heatsink.
The beam pattern (=the reflector) is maybe kind of a lottery but most likely not. I am so happy with my beam pattern ;)
It's definitely built like a tank!!
The major missing part in my review: runtime measurements with Eneloops and with Protected 10440's (and qualitative description of the brightness regulation).
I would ask you guys to help me with the review and provide some RL beamshots and wallshots (or comparative beamshots, in comparison to iTP A3). I dont have a digicam, so please provide some shots for this review thread, thanks!!
