I started work on adapting an ATtiny13A to a similar LDCH driver, the LD29, but have not gotten around trying to finish that work. Here’s that thread: here is the LD-29 MCU pinout (eg how to put your ATtiny13A in there…). I think that there is plenty of information in that thread for a modder with a strong interest to actually complete an LD29 project using a standard ATtiny13A firmware.
I think it’s fair to assume that the same thing could be done with this driver. It could even be using the same pinout for the MCU - but just as easily it might be a bit different.
EDIT: if all you want to do is completely remove LVP there may be a voltage divider that can be modified to just pull the MCU pin “high”. If you want to look for that just measure each pin with a DMM as you adjust the input voltage. We’d then just trace the pin back to the divider and remove the resistor that goes to GND.
