Those measurements are not correct. According to Manafont it’s 6" long and 1 3/4" diameter. Look at the caliper photos instead and it’s roughly 4.5“ long and just under 1" in diameter.
nice white tint from the xm-l t6 emiiter on trust fire flames it draws 1.25 amps with the battery charged to 4.18v so it should put out around 450 otf lumens.
im very happy with it its bright fits in your pocket and was cheap as chips and i should get 45 mins out of it using the trust fire flame batteries and its good to have a torch with no sos or storbe modes that will tail stand if you slight loosen the lanyard loop and push it to one side.
Not fond of this light ..it was a good deal from dino direct but the body feels uber cheap and the threads almost don't exist . The light feels slick and the knurling and adonizing are basic chinese lead paint . the tail is a split tail offering less stable tailstanding and 4 extra sharp edges added just for fun . It's pretty bright but the tint is not great /not horrible /not great .Silly green glow in the dark tailcap makes the light look cheaper than it already does and they never work anyway(fun for 11 minutes ).it's an OK cheap light
The "cheap chinese paint job" holds up quite well, already using it with the keys for a week straight and no scratches. Can't ask for more for $14 shipped with registered air mail. I think the Manafont batch could be underdriven. The one from Dinodirect is 3 amps.
At 1.7kHz PWM frequency, it is the best amongst the budget lights. It's even better than some Olights and iTPs, in fact!
it is a budget light, but im happy for what i payed, i chose the namafont one cause it is under driven dont need the 3 amp blast form this thing.
Boaz i agree with the green tail cap boots they make things look cheaper then they are... but not as bad as the jetbeam bc40 box, great light but the box was a joke made it look like a 5 buck kid,s toy lolls
sofar i will rate the trustfire brand higher then the ultrafire brand but im happy with this light ill give it a good run tonight.
im happy with the Uniquefire UF-2100 T6 1-Mode Memory LED Flashlight took it on a bush walk with me last night it puts out massive spill and will throw usible light to 80 meters and will go a bit more at 1.25 amp the host gets a bit warm but the pill and contact seams good, not sure how the other 3 amp clones would go with long runs but this one will do its job i got it for.
150 meters (164 yards or 492 feet) of good usible throw with good spill for its size
200 meters (218 yards or 656 feet) of throw.
i did not think it would do so well ive told other people it had good usible light to 80 meters but on a good night over a feild measured out it did alot better then i thought.
we used new fence lines that where walked out with a measuring wheel on a cattle farm, it realy helps to get away from town, cities and suburbia as there is to much light polution, but its hard to find a perfect dark place but last night was perfect clear conditions here with 1/8 moon.
we have distance tree's measured and marked out at 160 meters 205 meters and 300 meters and 500 meters nothing has been able to hit the 500 meters yet lol,s
this thing threw the pretty much same distance as my TF C8 that draws 1.6 amp on high at the tail cap just diffrent spill and intesity of the beam.
i like to think its not BS this to me was just not random stab,s in the dark as we whent to alot of trouble recording current draw, distance and re-measuring the distance to test 7 lights and i had another personson there with me to confirm and talk over the results, some lights surprised us and some disapointed us.
another thing ive noticed is a 1 amp xm-l does not realy throw any less then a 1.5 amp xm-l and a 3 amp xm-l does not realy throw any thurther then a 1.5 amp xm-l i was totaly surprised by this light !
Went out testing tonight. Weather was slightly bad/foggy and everything was wet.
UF-2100 on hi (3A+) threw about same (slightly better) as my UniqueFire G10 (w/ 14500), but hotspot is about 4 times bigger and spill at least 2 times brighter and plenty wider. Both threw about 140+ meters.
UF-2100 is very good on 100 meters range, it lights up huge area. Awesome medium distance light cannon :)
I'm loving UF-2100 on low too :love: . Throws to about 50 meters and spill is very wide and even. Perfect for taking a walk.
Now I'm kind of waiting for winter and snow... wanna see how far I can see then J)
EDIT: Tested max throw... about 185 meters. I could barely see (but not recognize) one of these
But had Sipik with me and it threw easily there :)
Yes, I know. Even my 980L is not the best you can get out of XM-L throw-wise. Fandy´s been on my mind also but next winter will be a really dry one on buying lights (no, not a pun here).
