I have an FW3T XP-L HI that I’d like to mod with the auxiliary board.
If you are re-flashing the driver to use the v2.0 board in three-wire configuration, what is the appropriate hex file? Will “FW3A_Anduril_v1.2_v1.5_v1.7_100% ceiling.hex” function with the v2.0 board? Is that the most current and full-featured version of the auxiliary-enabled firmware available?
Also, will 0.15mA be enough current to light the blue or ice blue LEDs on low mode? I want the option to have very minimal illumination if desired but want the LEDs to illuminate in both modes. Would 0.3mA be a better choice with the blue emitters?
yes the low mode is always a problem with color mixing unless you would design a 4 layer board with additional optional 1 or 2 diodes to even the voltage out fixed on a cross pattern
I don’t know about my friend who I did this for but I actually kind of like it this way, because it’s a way to have variety! Plus, just low orange looks nice and discreet
This would also mean a totally new driver with 1634 MCU, having 3 colors with 3 groups or RGB LEDs and 4 layer PCB
not worth the trouble as sales of these boards slowed down a lot
Can anyone please help me. My mate and I have a lot of previous experience with this kind of thing from custom building drones and we want to build some flashlights.
What we want to know is with regard to these Lexel AUX boards, do you have to use the stock FW3A driver? Can you use another driver like the DrJones driver for example? Or is it that you have to use the modified Anduril firmware?
Doesn’t the up-to-date Anduril firmware now support AUX out of the box?
See, here is what I am wanting from a UI:
- easy access to Moonlight from off (I also note that some drivers like DrJones appear to have dedicated hardware to make Moonlight awesome? Or am I a noob and Anduril does ML as well with the stock fw3a driver?
ability to turn off/on Aux LEDs. Ideally also control if they are on really low/normal low.
Can someone please explain what options I have here and also what hardware we would need to achieve this?
It look like lexel design the aux board to work with original fw3a driver which use 8 bit attiny85.
So, aux led is not support in anduril for that microncontoller. The aux led is not control b attiny, only by voltage. It look like loneoceans new lume 1 driver for fw3a support andril with aux led because it use different attiny. https://budgetlightforum.com/t/-/60947
