So, you quit on me? Can you explain what’s going on or not?
My OS says battery is charged but when I remove it and then plug it in again, it goes back to the same state. “28% capacity, 33% an charging”. I don’t know how the system says it’s charging, it charges and then, if I remove the power cord, laptop just goes off. And I can’t also understand how OS says it’s charging when it is not in reality.
I'd have said “your battery board is screwed up”, but since from this side I can not really assess it I just let you dig it some more.
Disconnecting the battery needs to be done properly, first and foremost from either V− or V+ (to power off the microcontroller) and when reconnecting either V− or V+ must go in the last place. Any shenanigans and the microcontroller will raise the permament failure flag and/or get some damage which you'll also need to diagnose and fix. I had to deal with this. I screwed up the original board, then tried to fix the battery with another board from an aftermarket battery whose cells were much worse. For whatever reasons I screwed up that cheap board too. Then I transplanted another board from a different old laptop pack whose cells were nearly dead, and at last I had to deal with reprogramming the firmware (for which I requested assistance since no idea, see my #11 post above). I thought this last step would not be required as the old battery was still slightly alive. However, the board's firmware refused to recalibrate with the newer cells. :facepalm:
Definitively your battery board seems to be screwed up.
