Yes. I have 18 RGBW leds in neutral white and only one RGBW driver from dr jones. So I’m making a quad rgbw
After using a driver like the op, those mce RGBW drivers don’t even count as RGBW. They can’t blend colors or anything like that. just one or two colors at a time.
I have plans to help out that situation. I had been holding off on the MELD driver for a while since I couldn’t solve some issues with my hardware, but I recently decided that I was just making the requirements too strict and it would be better to move forward with relaxed specs. I have a new MELD driver designed with regular AMC7135s for use in any single-cell light for rechargeable cells only. The new design also came with a microcontroller upgrade that gives it 13-bit (8000:1) logarithmic dimming on the white channel, which is an enormous improvement that, in my opinion from the initial testing, makes a huge difference in user experience, especially if you are used to lights with only 8-bit dimming. I also have the firmware updated to selectively turn off features, so that you could, for example, make a light that was just white and UV with the same user interface as the full 5-emitter setup.
Right now the new driver is .75” diameter, but I can make alternate versions in other sizes. I would like to ask those here who would be interested in an RGBWUV driver - what size would fit the lights you want to use it in? Keep in mind that your host needs a momentary switch, which can be the only switch or in addition to a power switch.
This is refreshing to hear! I love the dr jones driver, but I’ve tried for a while now through different methods and he has definitely gone dark. I would love to try your driver! Right now I would be interested in the size 19-20mm but 17mm can always be used with an adapter. I would buy one or two to start and see if I like them. Then maybe more. I will be listening to the conversation intently:)
Right now, I don’t have a host picked out. But, I’m thinking larger hosts would work better for me because I can’t work on stuff as tiny as what others do here. The good thing about larger hosts is that you can make smaller drivers fit. But, if you want to make a specific size, I know of one cheap flashlight that has an e-switch driver. The driver in that one is 24mm diameter. I’d suggest that you could make a 24mm driver with enough edge clearance to sand it down to 22mm, or even 20mm.
The screen is about $3.50, microcontroller about $3, miscellaneous other components add up to around $2 probably. The other things added are the amc7135s at around $0.40 total, the XQ-E leds at around $12 total, the uv led which is $26, and the led board which is about $1
I like the Dr.Jones RGBW driver, and your MELD driver looks awesome too (although without your ledboard and tiny XB-D and LuxeonZ leds I would not know where to mount the extra UV-led in a build).
What I really like to see sometimes is a 17mm (+15mm :innocent: ) RGBW clicky driver that is an upgrade over the existing clumsy intl-outdoor driver . With some tinkering you could design a smooth clicky UI, although with a bit less functionality than you can make an e-swith UI.
A clicky driver enables the use of many more hosts, and the build will be so much easier so more people will be doing a RGBW-mod.
Ugh I can’t stand the clunkiness of clicky UIs. I used to do those in my Super RGBW lights and have stayed away from it for many years. I do have a few ideas on improving the usability though. I’ll put some thought into it. I think a clicky UI could run on the same hardware as my new linear drivers.
Ai, they finally have run out of them, it was in stock for years. Mountain electronics sells them too, and I see only 2 listed, so that is almost finished too: Color and Dynamic White XM-L Driver - 17mm
Yes, I’ll have drivers available in about 12 days in 16mm (double stack), 19mm, and 24mm (trimmable). I plan to make an info thread about it once I have them in hand. I can also make programmed microcontrollers available immediately in the qfn package, though I didn’t expect much interest in those.
