You misunderstand. The pink one is for comparison to show the voltage meter is working correctly, same as you did with the charger.
Also you cannot show unstable voltage by holding the probes on for a second or two, you got faster and faster and by the last one you were barely even waiting a whole second. I just had a quick look and it seems you took about 13 seconds to supposedly show unstable readings on 6 cells, including time to switch between them. Pointless.
Well, friends were busy so I ended up using the above video, plus a couple additional images: a true Samsung ICR18650-30B top (from ;-) HKJ's review) and a shot of the fake cell cans:
Top rings are glued on.
Although still adamant on the goods' legitimacy, I got my money back:
Case closed.
Cheers ^:)
Original post date: Fri, 03/02/2018 - 10:53. Edited for typo fix-up.
i meant they look close enough to lg design to wind up rewrapped in lg looking sleeves.
a fairly convincing fake lg.
lg hg2 fakes are most often he2/he4 rewraps.
or a real laptop grade lg cell that has around 3000mah but no good at high loads.
After some reseating over slots 2 & 3 in my Lii-500, the shown figures are 29mΩ and 30mΩ and Samsung 25R comparable. :LOVE:
Winner!
Those are the cheapest 30Qs I've ever :-D bought. They even came with a protection circuit as a bonus.
By the way, fixing the inconsistent IR readings on Lii-500 chargers is an easy mod. They are caused by the spring to rail tab contacts, thus soldering a fully extended rail long wire from board to tab solves the problem. Not done yet, hope there's room for a few wire patches inside. :-D
A rail with high contact resistance affects actual cell voltage termination (dV = Itermination × Rrail) and hence the capacity readings too (cell reachs lesser maximum voltage and actual end of discharge cut-off is higher too: less measured capacity).
I got a pack of Sony VTC6 from AliExpress and another pack from a local vape shop (finally found a local vape shop that sells what I think are genuine cells and don’t cost too much compared to the previous local vape shops I visited).
The VTC6 from AliExpress actually ended up more expensive (I’m now paying expensive shipping fees for batteries, since relatively fewer AliEx shops ship to my country). I haven’t had time to fully build up a case (at 0.50A discharge rate, the local vape shop VTC6 actually registers 3000-3080mAh in my samples, and they have really low iR consistent with all the VTC6 I got from them, around 20mOhms using MC3000 to test). The VTC6 I got from AliExpress registers 2800+ mAh, and are around 30mOhms iR). There is also a slight weight difference (I weighed all of them). Not sure if enough to say that the AliExpress VTC6 I got are not genuine or some other reason… Will post in another thread when I get time.
Maybe you could post some pictures on how you did to improve the resistance measurement of the Lii-500?
They may as well be genuine at that price, but I cannot see how much are you charged for shipping. Why are you doubting? Actual wholesale cell prices are astonishingly lower than what you may be used to pay in vape shops. Cells, however, are an industrial product. There are no OEM brand warranties to cover your ass because of your own incompetence. Use wisdom and buy rewrapped cells if you need someone to complain against.
NKON sells 25R cells and many others at a cheaper price, with as low as €5 shipping in my case (post office pick up mode, though).
I have 2 of the batteries and they have stopped working and there’s corrosion under the wrapping, I bought them from a local market and plan on taking them back because I have had them for around 7 months and I just wondered if they are legit because I can only find this type of Samsung batteries from one source online
