Thanks for all your work and reporting on the impacts for the apparent production process changes Li.
Can you tell us what lacquer you are using or recommend using?
I don’t know anything about lacquer, but I imagine the recipes from different manufactures/product types might potentally behave differently optically and thermally.
There was no need for that imho with old xp-g2 s4 2b cause it had perfect tint and I refuse to use this method on new G2 S4 2B simply because it has crappy performance so tint shift to cooler one can’t change the fact it will still throw like crab.
If you want to experiment led seal(RMM) or judikins diamond glaze(Vinz) should work. If you’ll do that “the less is more rule should be applied” and watch out that dd emitter surface is ass clean and dry ass possible.
I haven’t purchased any Cree emitters in a long time. I have some old “T6” emitters that I dedomed a ways back that turned awful green. Wouldn’t mind trying to rehab them if it isn’t expensive. Thanks for the fast response Li.
I’m still getting about the same. I pretty much resigned to the fact that this is how its going to be. Thus the rating of my triple XML2 bulbs being 2,000 lumen. If we were still getting the low vf emitters from the good ol’ days I can’t help but think that number would be 3K. On the “bright side” run times and efficiency are up. If XPG3 is any indication of what XML3 will be we might get lucky and have super low VFs again some day…
