As it’s already been said, you don’t need silver. You don’t really need copper either. Aluminum is fine, and brass is good enough most of the time.
If you’re really that concerned about thermal performance, reducing the number of layers in the thermal pathway and minimizing the gaps between each interface is far more important than using premium metals.
I'm pretty sure aluminium Sinkpads are just regular PCBs with dielectric layer under the center pad. Its possible to solder to aluminium, but its not easy. Way easier to just use copper.
Copper/solder/whatever filling a pill doesnt improve heatsinking though. All it does is improve heat capacity.
You are right, they now offer aluminium PCBs with direct heat path. Last time I looked, they had copper and regular PCBs, but since its been about a year since I looked.. :D
Except for the fact that you cant connect the aluminium PCBs to the heatsink with solder, they should actually work better. But I wonder how they made the top surface solderable. Either pre-tinned or some special layer..
They do make low temp aluminum solder, it takes a few steps and special preparation to solder aluminum (namely cleaning with a STAINLESS STEEL brush to knock off the oxidation layer, but it is doable
I would think the easiest way would be to coat the aluminum board with copper, but I doubt that's the case. It's almost certainly pretinned, but that leaves a lot of questions too.
I need to get myself some of this copper solution stuff and try this out.
I guess in a factory you can easily solder aluminium. Something to keep the air from making contact with the aluminium and something to scratch away the oxidation layer and you are done. I tried that with an XRE aluminium board, solder, oil and a nail once. It worked but wasnt pretty at all.
As far as cost, silver dimes maybe $3, sandpaper is $1.39 at the local hardware. So not bad. Plus the dimes are smaller in diameter. And I think silver is softer.
I might use other countries too.
I believe Wikipedia says Sterling, 92.5%, is 361, pure copper 400 or so, pure silver a bit higher.
85% Cu brass 151 on one site.
i have used AL. sinkpad2, it solders just like copper one, heatpad looks like it was plated or something, or pretinned, as mentioned before. but it is not AL on the surfice. the heatpad has continuity with back of the star
A bar would be great. I may do that eventually. Unfortunately $40 doesn't buy much copper nowadays. At least I still have a copper lightning rod that I'll be pounding into filler when the pennies run out.
Maybe I should have written "could", but anyways, I think I read that copper has a higher conductivity rating but aluminium is faster at giving heat away (not emissivity). But since there is no real difference in performance between brass, copper and aluminium heatsinks, I dont think there will be much of a difference between aluminium and copper star..
