Do you have an article about batteries explaining those nomenclatures?
I did think those panasonics are the best.
Wow Daleā¦ I seriously did NOT expect that. I was expecting a 30Q or HG2, since Nitecore made so much fuzz about this āspecial high drain batteryā. I hope you have made it work with the 30Q.
Iām also surprised on how wrongly used is the āIMRā chemistry term.
Many years ago, probably true. But for todayās standards the PF does not even compare with a medium-drain.
We donāt have articles explaining nomenclatures, we have tests: (actually I think we do have such articles but a test shows it better)
The orbtronic 18650PD is based on the panasonic PF cell as per [HJKās review](Test/Review of Orbtronic 18650PD 2900mAh (Black) | Candle Power Flashlight Forum.
That applies for 3400mha too?
Whats considered med and high drain?
The PF is/was a decent cell, but lower internal resistance cells took over by allowing much higher currents in our FET driver based lights. Cells like the Efest Purple 35A, LG HE-2, HE-4, Samsung 30Q, there are quite a few these days that outperform the PF series from Panasonic. Even their own BD has higher capacity with better current capabilities.
To the best of my knowledge the circuitry is a protection circuit for over-discharge and low voltage protection, weāll need someone more familiar with electronics to verify what that circuit is. Thereās no components at the tail.
There isnāt a fixed definition but for our use a high drain is a battery rated to supply constant 10A, or a triple XP-L direct drive setup. If the 3,400mah you refer to is the panasonic NCR18650BD than that is a very low drain cell.
Med drain:
-Sanyo GA
-LG MJ1
-Samsung 35E
High drain;
-Samsung 30Q
-LG HG2
-Sony VTC5/6
Thanks Dale and Will34, Iām newbie with that
Those high drain cannot come with protection circuit?
I bought those too: http://www.banggood.com/4PCS-3_7V-2600mah-Button-Top-Protected-18650-Lithium-Battery-For-Samsung-p-913785.html
How many amps those can push?
Wow very unexpected, but nice find Dale. I really hope you are able to wire up that 30q.
And if you do, who knowsā¦we may possibly see 3300 lumens!
Iām actually surprised you purchased this light in the first place. What made you want it?
Would have thought u go klarus g20 or olight r50 route or acebeam ec50 version 2 ?
WOW
nice find Dale!
The stock output are already exceeded 3300 lumens though around 3500, check mhanlenās review.
I can vouch for his accuracy, as i also have this light and have proper means for estimation.
I look forward to putting the TM03 in the lightbox with the stock specialized cell and hopefully a Samsung 30Q variant, will be interesting to see if thereās an output difference. My TM03 is on the wayā¦
im really hoping the 30q works, and that it pushes the power for the strobe mode because it is waaaay under performing right now in stock form.
Not sure how you can take that stance, it far exceeds what any other 6V emitter does on a single cell.
But yeah, my goal is to see what can be done to push it. lol I donāt know where I got that idea, I mean, whoād do such a thing?
<ā- walks away whistling
i was only referring to strobe mode. i think i measured no more than 1000 lumens.
but yea , on turbo mode, this light kicks ass at over 3000 lumens.
i was really hoping that the strobe mode would also be 3000 lumens, which would have made it nice for a self defense situation, i was pretty dissapointed about that.
I would imagine that the Boost driver has spikes that would end up frying the emitter if used in full power on strobe. Something like that, anyway.
I am curious, as well.
PM with the price, please?
same here ,pm me price pls.
Yeah, Iād take one for free too!
Sounds like a nice powerful light, but the proprietary battery required for full functionality makes it much less desirable considering the $100 buy in. Clearly itās not for me. What a shame they couldnāt make it work 100% with regular 18650s.
Who got one for free?
The people that get a light at no charge to do a review certainly have to work for it, a good review is a time consuming and painstaking ordeal that can take several days to complete, and then thereās the plethora of questions that arise and usually more measurements and such. Might seem free, but itās a fairly expensive free!
The strobe mode uses random frequencies alternating. When itās on high frequency it looks like it outputs a 1000 lumens. But when itās blasting on low frequency it clearly puts out a whole lot more than 1000. My thinking is that maybe thatās the way this lightās emitter works. It needs time to reach higher lumens which a higher frequency prevented it.
There was a gent at the bottom of the first page who stated that heād take one for free (from Uruguay?). I seemingly turned around and another page filled up before I could post. (Maybe I didnāt refresh my page? I dunno.)
Please donāt jump to conclusions when reading what Iāve written. Iām perfectly capable of insulting folks openly and so that there is no doubt to my intent when I have a mind to do so. Thatās a very rare occurrence and I never fire the first shot.
