🔥 SKILHUNT M150 V4+ Upgrade is Here!
I believe the cross area is where the emitter lines up with, not the front of the light…
If I recall correctly, Bridgelux uses several different chips — the first is a standard blue, the second is specifically around 480nm, both claimed to have a wider FWHM. So it’s not about the phosphor. That’s exactly why the datasheets strictly define the current range — otherwise, due to different Vf values, the spectral mix shifts in a rather amusing way.
Father’s Day is just around the corner! :tada:
To celebrate, we’re launching our mid-year promotion:
「Father’s Day · Bright Dad Season」
Date: June 10 – June 21, 2026
Highlights:
Use code FATHER20 → 8% OFF sitewide
Spend $129+ → Get 20% OFF
Spend $89+ → Get a FREE E3A flashlight
The perfect time to treat yourself or gift Dad something truly bright and reliable.
Which Skilhunt light are you getting this Father’s Day?
It would be great to see EC200 version with F35R.
For this model additional throw would be a significant boost for usability and with high CRI it will be very competitive option:
  • SFT25R 5000K version spec is for 228M throw so if it F35R version can produce 170M it will be competitive with Baton 4 PRO
  • High CRI
  • USB C charging (many people will prefer that)
  • multi led setup has better efficiency
:fire: SKILHUNT H150 V4 Upgrade is Here!
Brighter than ever — now up to 1070 lumens!
More stable — new buck-boost driver keeps constant brightness throughout the whole battery life.
Cooler & more efficient — significantly lower heat generation at the same power.
Compact, lightweight AA/14500 USB magnetic charging headlamp. The upgraded H150 V4 is perfect for everyday carry, night running, camping, hiking, and work tasks.
:backhand_index_pointing_right: Learn more: H150 AA 14500 USB magnetic charging LED Headlamp – LED Headlamp │ Tactical Flashlight
#SKILHUNT #H150 #Headlamp #EDC #OutdoorGear
9 Thanks
that looks great!
sent you a Private Message with a question
Great news. I bought M150v4 on the day of its premiere and it was an excellent upgrade to M150v3.
I hope H150v4 always switches to M2 from L2/L1 with 2H.
It’s a mild disappointment to not see some sale during the premiere :wink:
:fire: SKILHUNT M150 V4+ Upgrade is Here!
:white_check_mark: Upgraded to 1100 lumens
Small, bright, and powerful — your ultimate pocket EDC flashlight!
Wow it is great news! I’m happy with H150 v2 and now I’m thinking about upgrade :slight_smile:
outstanding upgrade!
not just for the higher maximum, it also has lower minimum output.. very useful..
The M150 is a Total Package, with great LED options, and dual fuel capability.
Im also a big fan of the new BL-113C 1300mAh USB-C 14500 battery. The highest capacity USB-C 14500 on the market.
Does the EC150 also have buck boost driver? If so I will buy a few.
EC150 has 9V boost driver
@SKILHUNT could you forward this suggestion to your R&D department, a EC150 in headlamp form factor
OK, thanks
Use as general light at home above 4k to understand what is pleasant light. Prefered light temp is at incandescent lamps which are ~2700 - 3000k, in common.
As flashlights are used during lesser time so comfort requirements are lower to allow more efficient higher temp LEDs. But it’s not optimum comfort. Compromistic value is 3500-4500k.
As marketologists want to write more of runtimes/lumens and some (mb a minority) people agree to get a little higher performance by the cost of the comfort, so the temp goes beyond comfortable values of temps. Even up to blue 6500k terror for eyes.
Besides the comfort, nature environments are better processed with lower color temps ~3000k. This may mean faster reaction there, as besides to see you need also to understand what you see. Lower temps also are better for high moisture conditions as rainy and fog weather. This makes lower temps as more universal in usage. Besides you may tolerate the light for longer time with lesser eyes and mind fatigue, what may influence on trauma chances. Being outside of home somewhere in a park, even close to some town, - you don’t want to get traumas at all. Just correct color temp reduces such situations. Your pseudocomfort 5k and any >4k adds risks there.
