When I received my unit, I conducted a ~35min test run. Judging by eye, I set the brightness to a level which corresponded to ~70%(again judging by eye) of the brightness of my BLF SP36 LH351D 5000k when on TURBO. Head temperature stabilized and didn’t exceed 59,3°C(measured with pyrometer), body temperature stabilized at 54,5°C and didn’t exceed that. No step-down during this test.When I received the light, I calibrated the temperature sensor and set the thermal limit to 70°C.
I know it’s not very scientific, but for me it somewhat confirmed the impressive performance showed/stated in zeroair’s review.
If I need several thousand lumens to be sustained, my go-to lights are either my Trustfire TR-J20 or my favorite, the Trustfire TR-S700
Both are heavy lights as seen from some of the specs for the TR-S700 below, but a great deal of heat sinking is necessary to shed all the heat.
The lumens listed for the TR-S700 are actual too.
Model : TR-S700;
Dimensions : length 195 mm * 90 mm diameter ;
Weight: 1278 g;
The light source (LED ): 7xCree XM-L;
The maximum luminous flux of 3800 lumens
