will make it meet you ASAP ![]()
Ohh no, i just bought the SC13 519A, well i guess it will have a big brother ![]()
I currently do not own a Sofirn light. I’ve wanted to. But had other things I wanted more. This would definitely bump Sofirn up the list. Especially if it has accessible flashing pads and it’s offered with a low CCT like 2700k
or, Especially IF the bezel can be UnScrewed, not press fit
Or extremely glued on like the FW1a Pro. I ended up having to apply heat to mine to get it open. That was scary!!!
Totally agree with keeping the Sofirn UI 519A version, I bought 2 and one will be a gift at some point to someone who just wants some light.
I agree heavy glueing can be very challenging to overcome and I much prefer no glue…
When I do have to deal with glue, heat definitely helps. I like to be able to control heat to a limit of 100C. Sometimes I do that on my hotplate (has adjustable temp). Other times I use boiled water (automatic 100C limit) and just dip the tip of the bezel in the water… (while keeping my fingers crossed that no water gets past the lens O ring)
or sometimes I just put the light in the hot sun for half an hour or so… that usually works to soften the glue enough to get the light open
Hello friends in BLF, this is Sofirn.
Does anyone have the H35B headlamp? How do you like it?
Recently we’ve been thinking about upgrading H35B which uses 3* SST20 LEDs+ 2 XPE Red lights
Here is our plan: ![]()
- 2SST20 LEDS (6500K) + 2SST20 LEDS (4000K 95CRI) + 1*SST20 DR (red 660nm)
- one mode for 4000k leds, one mode for 6500k leds
But now we have following questions: ![]()
- Do we need one mode for both of 4000k and 6500k LEDs?
- How to arrange these 5 LEDs? Is this ok?
With these various LEDs and channels, it will be difficult to design the UI.
What do you think? Are you interested in it? Feel free to leave a comment! ![]()
The LED arrangement is fine, but the LED choice could’ve been better. The LH351D 5000K would’ve been a better alternative for the high CRI channel. 519a would’ve been perfect but cost would go up significantly, and the LH351D is easier to drive than the 519a. The SST20 6500K is fine for the long range channel, but the SFT25R is right around the corner, and there’s these mistery chinese round die LEDs that are showing good performance. The CCT difference between the SST20 and LH351D would be smaller, and with a button press combo we could swap between the flood high CRI channel and the long range channel, with another combo for switching between white and red.
No need for a mode where both channels are active, it only makes for a more complicated UI and possibly more heat.
I would like one, but please remember to use a modern T1616 and have the standardized flashing pads (like TS10). An indicator light in the switch could be nice too, like the SC21 Pro.
If possible, I would much prefer an efficient buck driver, if not then I would be fine with a constant-current linear driver. I wouldn’t care if it cost a bit more for the buck driver.
I would prefer the 519a 4000k or 4500k, but 5000k is fine too.
If it has those, then you have basically guaranteed another customer.
The last time I opened up an FW1A Pro, it had an absurd amount of permanent loctite, I was advised by the customer rep to use a heat gun. Took me half an hour with my hot air station at almost 400C, with pliers and a strap wrench.
If a bezel really has to be press fit, it would be nice of Sofirn to at least leave a groove to use for prying when removing it, like the back of some watches.
Hello Sofirn.
I do have one of these, it performs quite good, however I personally don’t prefer cutout-reflectors for their messy beam profile and high losses in spill-light.
Of course with 5 emitters in a light like this, it’s understandable though, but it would still be great, if you could replace it with a custom TIR-lens.
To your questions /
1: I would appreciate a mode for both channels anytime, first the tint-mix should look awesome, but also more emitters means higher efficacy and thereby less heat and longer runtimes, which this light certainly needs.
And if the UI is made similar to that from the “Wurkkos HD50” for example with a “click-hold”-command to cycle the channel-modes, it shouldn’t be too complicated either.
2: The red emitter in the middle is perfect, but I think alternating the white emitters to one-up one-down for both channels would give a more balanced beam profile in case you keep the reflector, also the heat is spread a bit more evenly.
_
I like the idea of a floody hi-CRI-channel and a throwy coolwhite channel. But that’s already the case in all the other multichannel-headlamps from Sofirn and Wurkkos, so to keep this a tint-mixing light would be alright.
Please don’t use “SST20”-LEDs though, the efficiency is pretty low on the 95CRI-versions. To my knowledge the “Latticepower TN3535” is also available in a 90CRI-version too that is even more efficient than the “LH351D”, but either one would be better, if cost-savings are priority. The perfect one would possibly be the “Cree XP-G4”, if you can get it in the “HI”-version without dome. It’s very efficient and throws far. Also it would be amazing for many enthusiasts if these emitters would finally be commonly available.
One more wish, many of these newer headlights have glued or maybe pressfitted bezels. Please keep the current one, just … screw it all !. It really makes for a good base for modifications. I have several “D25S” and “D25LR” with changed emitters and optics, and they are very useful. Having a more powerful alternative would be very welcome.
Anyway, thank you.
I had one of these but couldn’t stand using it. It kept on stepping down randomly even on a full charge. Also tried different batteries but it had the same behavior. Hope this is addressed with the upgrade.
Agreed, the use of a timed stepdown really seems inapropriate for a light like this, it should if so, only be done in large handheld flashlights with tons of thermal mass and relatively little power.
But here it either reduces power prematurely or when driven at high or turbo, it doesn’t prevent overheating as the user keeps reactivating due to completely not feeling the heat build up through the headband. This could be quite dangerous with the heat sources directly on the side of the battery and it itself strapped onto someone’s face.
Regardless of it is a timed step down or not. I kept on experiencing it within the first 30 seconds of turning it on. It felt like it was a dud or faulty code. I guess We can’t really expect too much at this price range. Never experienced this with the old D10 drivers though so who knows. Not knowledgeable enough for a proper conclusion.
Strange, could have been a one time-defect or do you know this behaviour from other lights ?.
Let’s see who will be the first one to get it! Don’t forget to tell me when you receive the package! ![]()
A light I got from SZFEIC has the same irritating behavior. No other lights from Sofirn though IIRC.
5 LED is not upgrade. 7 LED is upgrade, or 9 LED even better.
11 would be optimal of course, like this abomination.
_
On larger handheld flashlights I would indeed highly appreciate it, having more emitters for a better beam and higher efficacy. There was the “Mateminco MT07” and other Models from Noctigon and Fireflies, but today there’s barely any affordable equivalent.
I wish Sofirn would make a large Floodlight for single 26–36mm cells again, with 7–12 nice emitters under individual high quality TIR’s, and of course powered by a buck- or boost- +FET-driver with Andùril.
