It now makes 8659.5 lumens. a gain of 2280.45 lumens over the last iteration and 2884.2 lumens more than when it came out of the box a few hours ago. Sorry it took me so long, had to eat lunch and take care of some other bidness.
Sure Kawi, as youāre aware they only ran less than a minute while I tested the few stages of build.
PM me your addy, was there anything else I was supposed to be sending that Iāve forgotten? Some Samsung LH351D 5000K 80 CRI or something? Got a couple of Oslon Black Flats you can play with too if you wantā¦
Edit: Just cracked it back open and checked, no wires pinched and all wires still solidly soldered. No side switch light. Not that it really matters, Iād turn it off if it was on, but itās odd that it quit working.
Thatās weird. At first I figured I must have broken something, but thatās the same file I just put on mine and it runs normally.
I wonder if the driver design was changed at some point, or if a wire may have come off. If you plug in the usbasp and clip it onto the MCU, but donāt flash it, does the switch light come on? On mine, it does.
Odd, I had 3 5700K XP-L2ās in a sealed tape with the order label accompanying them, and 2 5000K XP-L2ās in a sealed tape with their original order label accompanying them, separted in my emitter kit and clearly labeled. I put the two 5000Kās on first, opposing each other on the board, then I placed the 5700Kās on the remaining opposing pads. Re-flowed it, assembled the light.
So now, checking with a UV light, it doesnāt look like what I know it isā¦
Itās not really a threshold sort of thing. Small differences have a small effect, big differences have a big effect. Just try to get things as close as you can, and the effects should be small.
I have a 2-slot charger instead of 4-slot, so I canāt charge all 4 cells exactly at the same timeā¦ but as long as I do each set of 2 one after the other, on the same charger, they end up almost identical. Itās probably safer than using two different chargers, since each charger has a different termination voltage.
