2 week electronic lockout battery drain test-
Nov 14 battery voltage (freshy charged) 4.145V
Nov 28 battery voltage 4.097V.
My light is not draining the battery when in electronic lockout.
I removed the spring by compressing the triangle so I could lift it out.
The magnet was lightly glued in place, but there was a small gap around the edges of its cavity. I inserted a small screwdriver into this gap and then lightly hammered the back of the screwdriver with the side of a pliers.
This worked quite well. The hammering broke the glue and shifted the magnet sideways in the cavity. The magnet fell right out after that.
Yes I know that but description is wrong led emitter choices are black, green and blue and body color is 5000k I thinking to buy SC10 Pro but if that’s SC21 have the same electronics I maybe will buy SC21 Pro, also my current EDC is SC21.
the advantage of SP10 Pro is that it is the only Anduril light that works with AA batteries, and it is thinner than SC21 Pro
the advantage of the SC21 Pro is that it is the smallest Anduril light plus has built in Charging and battery indicator light on the switch, and it is shorter than SP10 Pro.
Im leaning towards SC21 Pro, because of charging convenience as a gift light to a muggle (thats my excuse anyway). My prepurchase consideration is that Im not sure yet if it has the same low firefly modes as the SP10 Pro, which are the lowest Ive ever seen in an Anduril light.
In SC21Pro we will lose the big advantage of SC21 in that smaller size. It’s use buck driver which is important for that small battery to have longer running times. Also I think the new version of SC21 will be just another simple FET based driver without stabilization.
Any idea if you can save runtime graphs with ceilingbounce? I can specify an output name, but nothing is outputted. Can always take a screenshot, but then the graph will be low resolution. Or does it save a CSV somewhere?
Edit: nevermind, found it. It’s on the SD card, it just doesn’t show up with the normal photos/pictures.
I really like ceilingbounce app but it doesn’t work properly on my new Mi 11i phone. I think there is problem with Android 12 or high resolution light sensor. So for that I used my old phone LG V30 to take runtime graphs.
On a more ‘serious’ note: got a shipping notification this morning. Much earlier than expected, considering it explicitly states 15 days. Pleasant surprise!
Will do! Or maybe someone else get his/hers red SC21 before and posts pics, the shipping of my SP10 pro was a bit of disaster once the package got to EU. Took much longer than usual, but hopefully that was a one-off.
