You sliced it, but you didn’t dice it. Important step. By removing the extra phosphor that sits on the substrate and surrounds the die you lose all that yellow peripheral light.
Zozz did a neat photo documentary on doing this with an 70.2 emitter
Good news, this SP33 are available on amazon us now, please contact us@sofirnlight.com or PM us on this forum directly for nice price. Click me to purchase
Some supplemental impressions I would like to share about the new SP33 V2.0 (XHP50.2)
I've tested some batteries. All unprotected 26650s would fit, i.e. the supplied Sofirn 26650 5.500mAh, the Dolidada 5.500mAh (fake PLB-55A cell), the Shockli 5.500mAh and the Keeppower 6.000mAh, both PLB-55A cells. However, I failed to put in a protected Keeppower 6.000mAh as PCB and shrink make it too thick to fit into the battery tube.
The Sofirn lineup for size comparison...
Some tactical lights for size comparison...
Some non-tactical lights for size comparison...
I tried to create some kind of schematic to visualize the user interface. I hope it's useful. I'll be glad for any feedback if you see room for improvements
I also tried to illustrate how the boost driver works i.a.w. the modes and their stepdown behaviour. The dotted lined boxes mean you have to use a doubleclick to get into this mode. The side switch indicator will also work differently depending on the actual voltage of the battery. The 2min-stepdown will only be triggered on Turbo, i.e. 2.500 lumens. Depending on actual ambient temperatures the "high" mode can run stable. My SP33 has automatically shut off once voltage was depleted down to 2.7V, so LVP works.
Last but not least some outside beamshots on Turbo mode (2.500 lumens)
Bottom line: The SP33 V2.0 is a very nice allround flashlight with good thermal management, a hefty body, a simple but useful UI and a very good price/performance ratio.
