It’s important to keep in mind that USB-C only refers to the connector.
The kitchen sink of protocols and functions that the USB IF has dumped in its lap ensures that it will never be fully mature or easy — by choice, as it keeps adding to that pile.
It may not be a total fecal show, but it’s not far off.
What most users will get out of it is that — it’s small, it’s reversible, and it’s not as bad of a physical connector as Micro-USB.
They will probably also get faster charging out of it — and these have to be conscious decisions — if the correct adapter with the appropriate protocol is used, and the cable is rated for fast charging.
Fast data transfer? Nope. Gotta make sure the cable is 3.2G1 or 3.2G2 (FKA 3.0, 3.1Gx), 3.2G2x2, or Thunderbolt 3 (their high cost makes this obvious).
The only thing any of these have in common is the connector. It’s up to the user to sort out everything else.
Much of it could have been averted if the IF had some backbone in defining minimum specs for a next-generation of connectivity, but it gave in to cost, and the lowest common denominator instead. A classic by-committee way of thinking.
I have the SP36 BLF Anduril version on its way. Should I be concerned about using the built in charger? Is there anything I could check for example with DMM?
There is zero chance he could get any damages from suing Sofirn, or any budget Chinese manufacturer. It could have killed off his entire family, and he’d still get zilch.
If he was a American suing an American company, sure, he’d probably get an award of $10 million for a headache. But good luck getting anything more than a replacement from Sofirn. They’re not playing buy lawsuit-happy rules.
@Jake257: I fully agree with you that this incident is very unpleasant for you and your girlfriend and that something like this should not happen. After I saw your thread this morning I immediately asked Sofirn to take a look at this thread and help you sort the problem as quickly and conveniently as possible. As far as I can see Barry (Sofirn) has already taken care of your case.
But, let me do some quick summary:
1. In the manual you can unmistakably find following information:
Please contact us if you have any questions. If your product is defective please contact us for replacement within warranty period.
How come that you put up the assumption Sofirn had no reputable, accountable warranty and customer service without even trying to contact them? I have come to know Sofirn for some time now and as far as I can tell they spare no efforts to provide one the best customer services ever seen before. While some of my private messages to Imalent and Acebeam on BLF were never responded, Sofirn was often reported to answer quickly, friendly and helpfully by many people here on BLF. They also provide CS on other channels like Facebook.
2. While you were quite objective at the beginning of your thread, describing the issue and later on supplementing some pictures, you have afterwards started to "bitch & moan" about things of Sofirn's flashlights and the brand itself that are not related to the specific problem of this thread...
Now, these words leave the impression that you have a problem with Sofirn in general and that you seem to be quite biased by some other flashlight brands that are widely known to have faulty devices, too. What you call a "weird generic box" is what I call an effective way to reducing costs and offering a better sales price. If you need to have a premium box with some shiny brochure along with your flashlight, fine. But please keep in mind that these things come with a certain surcharge in costs. I guess it will not change things for you but I can assure you that Sofirn is working on some cool new design already while trying to maintain the costs at a very reasonable level. You were saying that the machining was sharp and that the anodizing had many imperfections? If you feel so negative about the product why didn't you return it in the first place and ask for a refund? All your personal discontent about Sofirn's quality is based upon 2 (two!) reported cases of a faulty SP36 driver. I'm not judging the general quality by only two reported incidents but so far I have been testing about 20-25 Sofirn SP36 flashlights - all of them were Amazon returns ("defective" or "damaged") - and none of them came defective from factory and none of them had any issues with their internal charging circuit.
I hope things will work out for you in a proper way and that Sofirn will get the chance to investigate the problem. No matter how hard research & development as well as quality control will work, there will always be a small percentage of defects with electronic devices in any products you can find. In my opinion, it's not only about if a problem happens, it's also about how a seller/manufacturer deals with the problem.
Funny , Sofirn IS online as I speak - http://budgetlightforum.com/user/23289 I wonder if they will advise you. I presume that it IS Sofirn, and not just a user called that.
I also agree entirely with the above post, apart from the ‘Barry’ bit - the OP would have no way to know ‘Barry’ was Sofirn, nor would I.
Many people have tried to help and advise, including me, but you are still carrying it on. Now they were overheating beforehand, you were already considering sending them back.
I get the impression you are after more than help, though I don’t understand what exactly?. I am starting to get the impression you don’t actually want to return it for some reason.
the li-ion electrolyte smells kind of ammonia ish, and kind of petroleum/naphtha ish
a plastic garden hose smell, may be from melting or burning insulation from hot wire
or overheated circuit board
or overheated heat sync compound - the whitish stuff
i;d inspect the battery closely,
if it seems ok, possibly put it in a charger on low current and close inspection
if it is normal, then it was the light
diagnosing the light requires disassembly
impossible if glued
would also void warranties possibly, esp if it was glued and you remove glue or unsolder thigns
maybe keep it a few more days and see if seems leaky or smelly
if so, put in a few plastic bags with warning notes “may be leaking CAUTION”
but only inside the box
As Barry suggested, it would be much more helpful for Sofirn and all of us if Jake was to send it back to Sofirn and not back to the Amazon warehouse. Sofirn has already agreed to cover the shipping costs. Once returned to Amazon there's no chance for Sofirn to investigate the problem any further. The defective unit can only be scrapped or sent as "defective" to another address ("removal order") but there's no telling which device came from which customer.
it could smell like any of these, or something else
depends on what burned, melted, failed etc
there are many possible plastics, paints, glues, coatings etc
Good suggestion. Please provide the exact make and model of the USB charger and the cable that you have used, Jake. It would really help to pinpoint the root cause for this malfunction. Without any further information we all can only speculate about the defect. I tend to agree with the assumption that the internal charging circuit was overloaded by a wrong voltage (9V/12V/20V instead of 5V) because the "handshake" between charger and charging circuit was mismatching and some safeguard function (surge protection?) did not work properly or was not in place.
Since Barry has been coordinating the BLT lantern project from the Sofirn side I’m 100% sure he is a Sofirn representative, and thus speaking for them on BLF.
I have no doubt at all you are correct, or anyone else, I am not questioning that (sorry if you thought that) - but having not bought that lantern or looked at that thread, I didn’t know, I suspect the same for the op or he would have contacted him already. I was merely pointing out that the username ‘Barry0892’ was not immediately recognisable as being Sofirn’s representative.
This does highlight a point though - maybe there should be a sellers thread, where all who sell etc on here store their contact details in one place (no comments from us) it would make it really easy to contact them then.
I know I could have used it in the past.
So okay, it seems the driver board had something cooking on it, enough to discolor the board itself through-and-through, even on the battery-ring side.
The cells are reportedly okay.
The light still functions.
Right there, that rules out batteries and driver itself, and points to the charging circuitry.
If it wasn’t expecting, couldn’t tolerate, and yet was hit by, say, 20V, any protection circuitry (PTC resistor, TVS, etc.) could’ve started conducting and shunting away any excess, just like a 7135 that’s hit with too high a voltage.
So it cooks, and cooks, and cooks, and protects everything else, but starts heating up and frying the board. Sounds like it’s doing exactly what it’s supposed to do, but instead of protecting against a transient condition, was left to cook overnight.
People here probably remember my pushback against using usb-c in everything, and one reason was I never liked the idea of a 5V-only device being hit with 9V/12V/20V, even by “accident”. Well Hell’s Bells, what does this sound like is going on?
Only a proper post mortem will be able to figure out what component(s) cooked, and then find out what it is. Once that’s done, then you’ll know what the problem was.
OP mentioned that he’d charged the light four times previously using the same charger and charging cord with no problems before it finally failed on the 5th time.
If the charger was supplying 20v wouldn’t the board have blown the first time it was charged rather than the 5th?
Sounds to me like the problem is probably a defect on the charging board inside the light rather than a defective charger or cord.
