You may want to consider this too.
Wow what’s that again? Any link?
Ill probably pick one up anyway. I still think they seem promising. Especially as mod hosts. I would really like to know if they have a decent pill though. I already have some lights that could need some work. Can anyone tell me? How is the T4 reflector? Nicer and wider than other quad lights?
I like the L2 design. L2 can be discussed in the Solarstorm L2 thread. Lets keep this thread to the T3 and T4 please.
Sorry, I didn’t mean to hijack this thread, just that I never notice about the existing of the L2 and happened to ask about it.
59 mm outside diameter so about the same as the SRK and M6. Large internal overlap between the four reflectors so that they overlap a lot causing the central peak where they all come together to be relatively low. Larger reflectors with more overlap and a lower center point than my 3 LED SRKs.
Inexpensive enough so I ordered one of each and paid via Paypal which allows purchasing without registering with Kaidomain. They did send a all numerics password using my Paypal email address as my account identification.
Personally I wish that more Chinese lights either used the magnetic ring interface with continuously variable output level or some variation on the two side button Fenix design with memory so the light comes on at the same level as it was in when last turned off. UIs that always start in the maximum output mode are a turn-off to me for high powered lights. Also I would like all of them to have a very low to moonlight minimum in the .5 to 5 lumens range. 300 lumens for low is way too high for night use in the house or many field uses.
You are wrong. The continuously variable/stepless adjusted brightness level is a very bad idea.
Read DENGOH’s comment here. He clearly describes why the stepless/infinite variable brightness level is an useless thing, and why the predefined levels are better. His comment is good, so I’ll quote it:
To me, their better UI was the old one. Not this infinite variable UI that sound better, but actually not so practical or should say slow. Predefined level is faster and cover most of the usecases. For example, a moon light mode of 1 lumens, low mode of 30 lumens, medium mode of 200 lumens, etc. But this infinite variable mode would be good new feature as add on, not totally replacing predefined level.
When I find that it is too bright, then I have to hold on the button to wait for the light to reduce brightness ramping up or down. That is what I don’t like as that is not comfortable to my eyes. When I find that it is too dim, I will need to wait for the light to ramp up or down either though not so uncomfortable to my eyes. I prefer there is quick way to go to predefined level.
But if you want a light with continuously variable level, buy TrustFire TR-S700 .
The reflectors on the T4 look deeper than the average 4-emitter SRK, Warrior, or Kung. Looks like this light will have a bit more throw than a SRK or Warrior.
More throw isn’t better. The flood lights are better (a mix of throw/flood, but if it’s more of a flood, then it’s better).
The reflector design looks promising too. Not sure if its deeper (no pro for me unless its wider). But it seems like its a tad wider/generally larger compared to the typical quads.
No. The reflector design looks disappointing. I don’t like spotlights.
3 X 18650 is the direction I advised them to take. Not the 4 x 18650. They almost made these new lights in 4 x 18650 but I had a lot of convincing to do. Too damn fat and uncomfortable.
Oh no. You convinced them to make it worse. You advised them the wrong direction.
4 × 18650 is much better, because it provides more runtime and more power for the LEDs. They should have to make these new lights in 4 × 18650.
You are coming across as quite gregarious or if vocabulary isn’t your thing then we shall go with rude to other forum members IMO.
Asorei;
You are presuming ramping controlled by a switch and ramping speed determined by the light manufacturer. I have some older Olight Infinitums with ramping controlled by head loosening/tightening and agree that it is a bummer. I was referring to continuously variable controlled by a magnetic ring like is used on many Jetbeams, Nitecores and some others. Calling any UI WRONG is to me narrow minded and presumptive that your opinion is better than someone else. People, uses and circumstances can cause UI preferences to cover a wide range. Remember what they say regarding opinions and what they are like!
The ring may not be ideal as the parasitic load, particularly at low output levels, tends to be high but to me it is still an excellent UI. I also have a couple of lights with the RMM 7 level UI and one SupFire M6 coming with the newest version of it which may eliminate my minor dislikes of the older version seeing as how the changes are based on my suggestion to Richard
FT listed LED temp 8000-8500K. Is there obvious bluish tint?
As Rich pointed out, the tailcaps seem to be glued. If anything like the K2 -- I hope not. I tried all the techniques to open the K2 tailcap with no luck - nothing worked to open it (strap wrench's, in bag in boiling water, heat gun, etc.). It's a show stopper for me - not mod friendly.
Got my T3 today from KD, looks good so far but the UI takes time to get use to I think.
Tom E: Have you tried the inner cap att the end? The outer seems to be in one piece. Haven´t tried yet!
Is the on/off markings the wrong way maybe or is it a function that I´m not aware off yet?
Sorry for the bad English!
Didn't see an inner cap on the K2, hhmm. I'll take another look this eve.
Tom E: Have you tried the inner cap att the end? The outer seems to be in one piece. Haven´t tried yet!Is the on/off markings the wrong way maybe or is it a function that I´m not aware off yet?
Welcome to BLF.
Welcome to BLF.
Thanks!
Tested it in the basement and it´s much more blueish and spottier beem compare to PD35. Gets hot very quick wich is good I suppose!
Got my T3 today from KD, looks goo so far but the UI takes time to get use to I think.
Yes, you are right. There is an inner cap screwed in. The outter part is part of the battery tube body.It is not like the k2. The k2 springs were generic steel. The t3 and t4 springs are a brass copper color
The head on the t3 is different than the t4. I dont see why they should be interchangeable with the battery tube. The t3 has the same reflector as the warrior. The t3 is smaller/more slim than the warrior in the front head. The t4 is bigger/fatter than the warrior in the front head. The t4 reflector is much deeper and wider.
I think the quality control on the machining and anodizing are nice. I really dont think anyone can nit pick for a $30 light.
The xml tint in t3 and t4 kind of suck. Cool white. Bluish cast.
I made my original fit comment because my T3 battery tube fits BOTH my T3 and T4 without noticeable slop while the threads on the T4 battery tube are just enough larger so that it will not fit the T3. A matter of just a few thousandths of an inch too large. T4 threads are only about .0025” larger major diameter but that is enough to cause interchangeability problems.
I also have three SRK type lights which appear to be from 3 sources, two are 3 Leds, one black SRK and one gold anodized SecurityIng and the last is a black 6 LED SRK version but with a different looking SRK marking than the first light. All three have interchangeable battery tubes even though they look to be from different sources.
Would you recommend getting one or hold off?
