After seeing your picture I started to wonder, if you could built S2+ with S2 pill and S2+ reflector. Then it might be possibe to use 18500 tube with 18650 battery. Kind of full size shorty S2+.
Well, maybe I someday try to build 18650 using S2+ with Jaxman 18500 tube and S2 pill. Kaidomain has those pills separately for sale if I remember correctly.
Nope, you can’t!
The logic is precisely inverse to what you say! If you use the S2 reflector/pill in a S2+ (which is already shorter than the S2) you will eventually reduce the space you already have for the 18650 battery with and 18650 tube.
The mod you can do to have that configuration is to turn the S2+ into a triple, by using the S2 pill in a S2+ .
I’ve done that mod inspired in some other people’s mod, too.
Sorry, I misread your post! :person_facepalming:
Yes, indeed, the S2+ reflector and the S2 pill make it shorter! Still, to make an 18650 fit there, it is virtually impossible.
Below there is a photo showing how much an 18650 stands out the tailcap+18500 tube. Allo a margin of 4-5mm of compression there, due to the spring on the switch side.
On the side you see the S2 pill w/ S2+ reflector and the pill with optics of a triple. Even with that margin, you wouldn’t be able to fit it.
Unless the driver and the switch base were almost “flat”, and still, I have my doubts that you could fit an 18650 there.
Oh, and please note that due to the differences in threads, not all the S2 pills fit S2+ heads!
