[Solved] XinTD SC-82 v4 only 2.7 Amps? (Solved now 3A)
I tried adding some copper braid (copper solder wick) and it didn’t make any difference. Then I tried replacing the spring with a Phosphor Bronze Spring from Convoy I happened to have, again no difference.
I took readings of all three modes and they all seem a bit low across the board compared to Foys XinTD SC-82 v4 review.
Burggraben Foy
Low 0.036 0.04
Mid 0.611 0.71
High 2.664 2.91
Since even the modes which require less ampere are lower it makes my layman brain think that there is no bottleneck anywhere. If a thin/damaged cable would limit the high mode amp then the mid and low should still match Foys values. They are all lower though, which a bad 7135 chip could explain. Thoughts?
