If you only have one mode when there should be five, it does sound like you have a short somewhere.
Mine arrived today as well and I pretty much agree with all the comments so far. Internally it’s a step up in quality compared to the other budget S5s out there, so it’s a bargain at $3. The metal switch housing is very unusual at this price, but I particularly dislike that sharp tail cap. Luckily all body parts and internals are fully interchangeable with the ‘other’ S5s so you can mix-n-match. I now have the best of both worlds - threaded pill for better heat sinking and a more comfortable tail cap that also tail stands a lot better.
If, like presterjohn, you dislike the thin pencil beam of the XP-E, a simple but effective mod is to put some Blenderm tape over the lens. This acts as a diffuser and gives a nicer beam for indoor use.
I agree but I don’t know where. However without notice all my modes are back again, but now it seems to be pulling between 1 and 1.2a on high .5a on med and .25 on low. This is with an XML.
overall its a bargain when you compare it to some of the crap at that end of the price range. I.e some of the new sk68s.
If you got one mode with very high amperage earlier, pretty sure you have bypassed the driver altogether. That may have happened if you created a short on the negative side of the emitter, current goes straight to the body and you get your direct drive, one mode. Limited to 2.8A because of the thin wires.
Now somehow the short is gone (stray wire or something?) your driver gets back its function.
@pulsar. That’s what must have happened I guess. What I have done, now that its all working, is put a little superglue on the bare wires where they are soldered on to the led.
@tristan. At first I used the white ring that comes with the reflector, but I think it steals some lumens so I removed it and if you are careful you will get it centred perfectly. Remember the reflector is plastic so no probs with shorts. I’m sorry I don’t have an hosting account so no pics.
No worries, thanks Marc. If you want to increase current you could do a resistor mod. If you want DD (while also keeping all the modes) you can just bridge across one of the resistors. I would not suggest it though without a cooper star.
I got mine yesterday. It seems quite nice for what it is, a small fixed focus 18650 light with a small LED for low cost and for throw. $3 would be a nice price for an aluminum battery carrying case, if it had not works at all. Thanks Werner for showing the solid pill. The head and tail threads are the same size, and they clean up nicely with oil and friction, because they fit well. From Werner’s last picture, it looks that the current can be increased easily, by shorting across the row of resistors. With the solid pill and with some added heat sink compound behind the star, it looks like it could take more current, in spite of its light weight. It is slimmer and lighter than an SK-68, but longer. I measure 120 x 23.7 mm.
Orderred 2/4
Shipped 2/8
Arrived 2/19 (to the WestCoast SF bay area)
Pretty good shipping and delivery time.
Light seems pretty well made. More than worth it in my opinion.
Threads were lubed with some oily stuff. Wipped clean and just tiny bit of my own lube.
Threads were not great , but not bad either. Better than most cheap lights but not at the Convoy’s level.
One side is labeled” Supfire” and the other has some chinese letters and 8 digits printed on.
Head and tail can be easily taken off.
But the light is very bright on HI…. I don’t see a reason to mod it unless you’re a hot rodder!! Haha…
If someone would write up a detailed list of things you would need and step by step instructions to up the output a bit would be nice.
