Ehh, it’s in a different size class with 8 batteries plus maybe $400. It’s been on the drawing board for over a year. Maybe it will be released, maybe not.
I prefer smaller sized lights like DT70 and under $200 price. It’s more sensible.
Thanks for the review. I think the light deserves the enthusiasm for how much throw it gets with the output. I tested a little flattop IMR adapter that came with the TM28 in my ddt40 light and it works fine. I’ll probably use it in the DT70 when it arrives and just stick the protected q30s from DT70 into the TM28. I am fairly certain that using 4x unprotected HE2 high drains will get better results for output. These cells put out more amps than 30q. Not that it’s absolutely entirely necessary to do this but…another 1,000 lumens won’t hurt.
I have the 35 on the way. Wish I could tell you when but as of just now I still do not have a expected delivery date.
And I tend to agree with you, many people forget about the ton of crap lights many years back that are top brands now. I am 50 years old in a few months so I have seen a lot of lights, many of them are top shelf brands now after half a dozen junkers over 8 to 10 years. If it is hitting 13k lumens with a claim of 16k, that is not really too bad. No it is not 16k but when you get into numbers that high is relation to a normal EDC we accept lights everyday that claim 1500 or so lumens and in reality are closer to 1000 to 1100.
I wonder if the homemade integrating spheres that are used by reviewers to measure lumens are even accurate at these super bright levels.
Does Imalent send out a sample to a lab to be measured? If so, maybe they chose a sample was a little brighter than the retail lights?
Everyone knows lumen ratings by manufacturerers might be off so that’s why we read reviews, to see what it is in reality.
Now I base my judgement on it being 13k to 14k lumen. For $170-$180, that’s pretty damn good. Then look at other factors such as modes and reliability, warranty support or lack thereof, etc… to determine if I want to buy.
I’m not mad at them for saying 16k lumen when its a bit less. Besides, 13k to 14k should run a bit longer than 16k and I doubt you’d notice a difference in brightness.
The light is only 4x 18650 in parallel. How bright can it be? The brightest stock single 18650 xhp-70 is only 3,000 lumens if even that. 3,000 x 4 = 12,000 lumens optimistically. Have any of us seen a single 18650 XHP-70 that gets 4,000 lumens stock? So how can there be, by way of having four of them in P, 16,000 lumens? I know it’s possible, but it’s insulting when a company that is seeking reputability continuously, as a pattern, plays the little lying game around specs. Recently the big names, pretty much have all tightened up when it comes to publishing numbers for lumens. I see mostly within 5% and many measuring greater than the listed spec. Obviously Imalent is doing the same thing they’ve been doing for years which is to add 25% to actual numbers in published specs. This hurts the industry and is not even necessary.
It don’t seem right. They have made a decent and original product with the first 4x XHP70 pop can and deeper reflectors than we’ve ever seen in this style light. Lumens already beats anything currently available in this size. Why not just be straight up about numbers? I get that more and more people are getting turned on to high end flashlights, a 16,000 lumen banner simply makes more of an initial pop. But it definitely hurts their reputation more when they do this and I think it is right to call them on it. It also drives up the probability that other manufacturers will follow suit. Not good.
That said, this light looks to be an awesome performer and I’ll be looking forward to getting mine and testing it out.
It can be 20k to 24k lumen, assuming you don’t care about run time, but how many people would buy that? A few dozen maybe?
Manufacturerers want to sell “thousands” though, so they have to dial them down to find a balance between output and run time.
The little manker m34 does 7k to 8k lumen, but only for 30 seconds. Now that frustrates me.
This DT70 doesn’t frustrate me as it looks usable. I probably wont buy the DT70 due to their lack of warranty. Especially since there are several of their 4 new models with driver related issues. That is dissapointing.
with 1s4p, they must use Boost Driver
as far as i know, at the same power, Boost Driver has lower efficiency than Buck driver
and boost driver require higher current, which result in more heat
They have a warranty in theory. First they will give you the runaround to avoid having to warranty it. Then if they agree, it costs $65 to $170 to ship it back to china. There is a high chance it will not reach its destination. I don’t think it can be insured through china post so you may loose the light and the shipping cost. If it does arrive safely in 1 to 2 months, it may take them a month or so to fix it and then it will take another 1 to 2 months to get back to the usa.
So would you call that a warranty in reality or in theory?
I would love it if they sold parts, like the driver that I could swap out myself, but they dont.
Actual design doesn’t seem too far fetched. Wouldn’t 4 parallel XHP70 result in a ~3 Vf of the collective sum, using the 12 Vf LED. From there, its not too much required by the driver circuit. to bring 4.2V down. Actual brightness would then be limited by the wattage output capability of the 4P-18650 bank of cells. Thermal sag of course would be a big problem at these power levels.
The convoy L6 does about ~3500 OTF, factoring in optical losses its probably doing “close” to 4000 Emitter lumens. Mine gets nice and toasty after just a few minutes. 4000 Lumens from each of the four XHP70 would certainly heat up FAST in a host this size/mass. If it does deliver ~3500+ lumens from each XHP70, I would think its only for a very short time.
Curious, how many watts does 4P-XHP70 emitters need to generate 16000 emitter Lumens ? Can a 4P-18650 group of cells even deliver that kind of power?
Still I think its a cool design. Amazing how far the SRK and the soda pop-can design has evolved.
Yeah.. no cheap way to ship to China. Normally I don't log into my PayPal account for a overseas purchase I just use my bank card and let it process through PayPal. If there is a peoblem and I did have one on eBay a few months back. I try to resolve it, when and if that does not work. No PayPal involved. I log into my back Visa account and dispute. Almost always merchandise not as promised is all they need. That problem on eBay, back in my account in 48 hours.
I’m getting around 16,000 turn on Lumens doing my ceiling bounce test. My 7300 lumen TN36UT hits 600 lux, my 8,750 lumen TN40vn hits 1000 lux and the DT70 hits 1600 lux.
The DT70 drops just 1400 lux in 20 seconds or so though.
Still very impressive as you’ll lose about 4,000 Lumens through the shaved domes
Honestly, that’s really impressive. Some time ago I read about the DN70 that the 2nd batch will have an update driver that would put out more lumens, as the first generation was quite under-powered. Who knows, maybe the latest batch of the DT70 puts out much closer to the claimed 16000 lumens…
