So at some point between 2015 and 2016 Fujitsu has cheaped out on their batteries. They are using crappy washers. I ordered several of the regular white AA’s and noticed that the washers were not completely round, so when the cells were wrapped they appear “dented”. Also, a few of my batteries came with slightly damaged wrappers. I also ordered several of their high capacity black AA cells and the problems were worse. They are no longer using the blue-ish grey washer but instead use a black plastic washer. This new washer is inferior because when the cells are wrapped it leads to a loose fit around the positive end. The washer does not sit flush on the battery and is buckled up a little. I do not see this on the white cells and they use a plastic washer.
I spoke with a Fujitsu sales manager about this and he basically confirmed that they are using different materials in their high capacity cells because it is supposed to provide more longevity or something. Seems to me they got it wrong and the new materials will just lead to torn wrappers more easily. He also said the black washer is the same thing they have been using on their white cells, just black. This is not the case though.
