could you run 3x AA cells? It would only be 0.3V higher charged voltage.
If you put the cell in some kind of metal case that would protect any fire from escaping yet not turn into a pipe bomb, then I suppose it could work, really depends on your attic and how flammable it is.
I would basically plan on the cell venting, if you would not feel safe with it actively venting, then I would not use it.
I could but I'm not certain how much safer would really be. Given the rated temperatures on the cells, I would definitely exceed the ratings on the eneloops but I would not exceed the rating for the vtc6 or the Samsung 25s /25r, I would probably not exceed the rating for my lg cell (70°c). I had a bit of a fish around for data on eneloops behaviour at elevated temperature but couldn't find anything. Lions however I found this paper which shows thermal runway onset temperature for various charge states, cells that are not overcharged all went into thermal runway over 140°c which leads me to believe the data sheet. Unfortunately they didn't actually state which cell they tested.
I just got two VTC6 that measure internal resistance of 47 and 67 mOhm on 1a discharge in my MC3000 charger. From what I read here it should be <<40mOhm. Did I get second-grade cells?
Update: Looks like MC3000 only measures IR in the beginning of the cycle. After dropping 400mAh, I restarted discharge and it measured 30 and 43 mOhm already. Does it make sense?
You mean resistance of the charger terminals?
After some more tests, it behaves as follows - I place VTC6 in, say 1st, slot. Start discharge. MC3000 measures IR about 50mOhms. About 200mA down, I restart the discharge program. MC3000 measures the IR again on start and now itâs down 5-7mOhms. Eventually when the battery was about 3.9v, IR stabilized at ~30mOhs, which is what is reported in the beginning of this thread.
So does IR changes (decreases) with discharge? Again, I was not touching battery/charger in that experiment - only stopped/started discharge program through the app.
HJK, I have read your IR measuring post [1] and it made me even more puzzled - you say IR increases as capacity drops, but I see the opposite. Unless itâs the temperature rise, which I doubt, since it was 1A discharge for ~30 minutes total and the battery was cold to touch (room temperature).
Try to clean the contacts on the MC3000 slots and also clean the VTC6 top & bottom first.
Then seat the VTC6 on the MC3000 slot.
Press both the UP and DOWN keys on the MC3000 simultaneously, it should show the IR readings,
try to do it again while rotating the VTC6 cell and check if the IR reading changes significantly (usually it will change slightly for flat-tops, since rotating it slightly may make the contact slightly better or slightly worse, at least from my experience with my MC3000âŚ
If I recall correctly, a good VTC6 will generally register somewhere around 25mOhms reading on my MC3000 (assuming the VTC6 is not very discharged, and not a really old/used up VTC6)
Yeah, flat top and less than 10 cycles. Purchased several weeks ago (doesnât say anything about their real age obviously).
Thanks for the hint about IR measuring shortcut - very handy!
I did some more tests including cleaning, rotating, etc., and results are below.
I got 2xVTC6 and 2xMJ1 from source A and 2x40T from source B.
both VTC6 and MJ1 on MC3000 show much higher, 20-30mOhm more on MC3000 when fully charged compared to highly discharged. Doesnât happen with 40T - just 5mOhm variance.
Here are the details:
VTC6 1: 70mOhm at 4.21v <â- last charged with Lii-500S
VCT6 2: 35mOhm at 4.01v
When I charged them last time they started at 3.5v and both measured 32mOhm.
For comparison I have 2 pieces of 40T and they both measure 18-230mOhm regardless of the charge level:
40T 1: 20mOhm at 4.14v
40T 1: 24mOhm at 4.25v <â- last charged with Lii-500S
40T 2: 18mOhm at 3.73v
I then tested a pair of LG MJ1 and they show:
MJ1 1: 65mOhm at 4.14v
MJ1 1: 85mOhm at 4.23v <â- last charged with Lii-500S
MJ1 1: 55mOhm at 4.09v
MJ1 2: 70mOhm at 4.18v
MJ1 2: 53mOhm at 4.08v
All of the batteries were purchased during the last month and have less than 10 cycles on them.
What worries me is that when charged with Lii-500S they end up with more than 4.2v voltage. E.g. I measured voltage using all my instruments on VTC6 last charged with Lii-500S two days ago and got this:
MC3000: 4.21v
Lii-500S: 4.19v
Nitecore UMS2: 4.19v
eevblog BM235 DMM: 4.213v
Uni-T UT216C DMM: 4.207
Higher-end instruments show that batteryâs voltage is above 4.2v. Does Lii-500S overcharge the batteries a little bit? I see that MC3000 by default wonât even start charging if the voltage is above 4.15v and once the charging finishes, the voltage drops to 4.17-4.18, while after Lii-500s it stays on 4.2v (and more as I see now). Topped up again my MJ1 from 4.14v to full on Lii-500S and once done, the battery voltage is 4.237v according to DMM and 4.23 at MC3000. And again with 40T on Lii-500S at 2A which ended up with 4.25v!
Hi, there. I am interested in understanding how you considered reaching of thermal cut out (80°C or rather 91°C) by testing the VTC6 cells at 20A and furthermore 30A. In the plotting chart it is possible to guess reaching 55°C (supposed on the external surface by LM35 you mentioned in the test setting page).
I am guessing you should have a thermal resistance value to determine this 91°C.
Thanks in advance. Regards
The temperature scale shows temperature increase, you have to add around 25C ambient to that. My log show the measured temperature and works to above 100C, but when drawing the chart I subtract the ambient and limit the scale.
Where did you find this? I ask because the official specification I can find (this 1-page datasheet from Murata) explicitly states 150mA (âCharge: 4.2V/3A/150mA cutâ).
It may very well be that it came from some official document you had from that time you stated it, and that this document is no longer available, because I myself can find no consistent âofficial statementâ on the End-of-charge current anymore:
The same document I pointed to above (straight from the current Murata website and listed directly under their âCylindrical batteriesâ product page, so it doesnât get more current nor official than that), besides indicating Charge: 4.2V/3.0A/150mAcut(sic missing space) under each of the test graphs as part of their âTest condition(s)â, also lists at right at the top Charge: CCCV, 3.0 A, 4.2 V, 2.5 h, at 23deg.C which seems to indicate there should be no ending of the charge based on the residual current, but just keep charging the battery at CV for 2.5 hours (since the start of the charge? since the start of the CV phase? who knowsâŚ)
Some googling also brought this and this, Dog knows if they are âofficialâ or âcurrentâ, but they also indicate the â2.5h with no termination currentâ thing, and also a DIFFERENT end-of-charge current of â100 mA cutâ (p.5 of the second one).
This is really confusing. Iâm helping a friend on a project that is now going to use a couple of those VTC6 batteries and I simply canât get any consistent, official and up-to-date information on how to charge the damn things⌠:-/
Just keeping this thread posted: given the current official datasheet for the VTC6 from Murata embed the phrase âCharge: [âŚ] 150mAcutâ in all its four graphs, and given that 150mA is also more conservative (in terms of putting less stress in the battery, therefore being safer and also extending its cycle life), Iâve decided to go along with that as a charge termination current. I will also use a 2.5h total charge time limit for additional safety.
Will now do a batch of 5 C>D cycles on my Gyrfalcon S8000 Pro charger, and will come back here to report the results.
