Test / Review: Xtar SP2 charger
Yikes, not a very hardy charger I suppose?
IMO there has been really low amount of failure reports on WP2 II and I presume there are a TON of them in use just on this forum alone.
I remember reading this one and one before.
I would still say it is above average and not by a smallest margin.
I had no hesitation in ordering the same as a replacement since there really isn’t anything better available for under $20. It started acting up with one side not starting a charge unless a cell was in the other bay. Then, finally it went into blink mode. I suspect these could use a bit more ventilation.
Two Xtar chargers @ $20 each plus your time and shipping = one Pila. If you do it right the first time, you win. :slight_smile: I’ve had a pair of heavily used Pila’s for over 3 years with no problems at all. Some corners aren’t worth cutting. JMO
At the moment, I have ordered maybe 6 Xtar chargers, have not counted recently...
All still working. 6 x Pila would have been ~240$.
But I have to say, these all are for leisure / hobby use, flashlight use. Not professional use.
Sometimes I do not cut corners, had generic c*** AA-charger and got frustrated (batteries were eventually the fault) got MAHA & Eneloops straight away :) Needless to say - They Just Work!!
Hmm.
I noticed I could not find these with EU-plug without adapter.
Any source for them?
I know WP2 II is available with EU-plug power supply.
CT, what’s the cheapest price you’ve found?
Thanks.
Thanks for the review!
Which one do you recommend or which one is better?
Xtar SP2 or Sysmax i4 Intellicharge v2?
Found these in here: What do you think about bestvaping.net? Any ideas?
eBay and SBflashlights seem to go hand in hand, about 45$ with shipping added.
edit:
too bad I did not ask bestvaping for SP2…
Just ordered Xtar batteries. Shipping is not shown in web page.
For 8 x 18650 it was about 11$. I think this charger will cost far more to ship.
Hmm.
I wrote eMail to ask about the shipping. Got too curious since the price is pretty low for the charger alone.
I would go for the SP2, I like the 3 charging rates. I do also prefer chargers that do not pulse the current.
I cannot comment on the shop, I have never used them.
Thanks.
At bestvaping.net, Xtar SP2 cists 17.70$ + 16.64$ for shipping to FI.
This adds up to 34.34$, which I think is quite good price.
Bestvaping has been answering to eMails pretty quick, although there was a small misunderstanding since they were thinking I was some other finn.
(also my fault, did not supply my order no. but it was not needed anyway, since I was asking JUST for shipping. They got carried away probably since I mentioned “Irecently ordered batts etc.”)
Hm, correct me if I’m wrong, H, but if I remember well, pulse charging is good… well, at least for NiMh batts :expressionless: For li-ion constant current charging is better?
Thanks in advance.
Same price @PWS
http://www.powerwholesale.net/xtar-sp2-36v37v-liion-battery-charger-with-car-charger-p-2053.html
Same price @PWS
[/quote]
Any quote about Intl shipping?
I guess they are the same company :slight_smile:
http://www.sz-eyoung.com/
http://www.sz-eyoung.com/sdp/1232278/4/cp-5546615/0/About_us.html
http://e-young.company.weiku.com/
http://efest.en.alibaba.com/
http://efest.en.alibaba.com/contactinfo.html
http://e-young.en.alibaba.com/
http://e-young.en.alibaba.com/contactinfo.html
http://www.bestinone.net/index.php?route=information/contact ( Tel numbers here same:)
I also remember one more site of them but can not remember name of it or maybe I remember wrong.
Quoting myself :slight_smile:
As for PWS and others… what’s the point of creating dozen, identical webs with the same stuff, etc.? :expressionless: Same happened to CQG.
Hi, I also really liking this SP2 charger along with their WP6 II, but recently my SP2 were a bit strange :expressionless:
Whenever after it charged a battery off the right slot with 18650 at 1A or 26650 at 2A, the led will blinks red/green continuously after I removed the battery.
I tried cycle the input or let it rest for 10-15mins, power on its still the same, until out of sudden, it return to solid green (w/o battery in the slot)
At first I assumed is the heat or something, so I try again with another 26650 @ 2A, while I stand up the charger, after it charged, red/green blinks again after battery removal :frowning: this doesn’t happen on the left slot ever.
As while it was blinking red/green, I put in a battery & it will still charge it (solid red till green, and blinks again when battery removed).
Does any one having this symptom ? or should I return to the seller for replacement ?
Have you had a look inside?
The reason the WP2 was so unreliable is there was only the protective coating on the pcb preventing a short circuit. After a few uses, the battery terminals wore the coating away causing a short (and potential electrocution)
