The Narsil v1.4 and NarsilM code has the option to turn the light on at highest mode
but instead alter the code to Moonlight would this code change do it?
I got atm only a assembled light which is potted so I cant test it
#ifdef STARTUP_LIGHT_OFF
modeIdx = 0; // power on with no output
#else
modeIdx = 1;
if (ramping)
outLevel = rampingLevel = 255; // power on at moonlight
SetLevel(outLevel);
#endif
#ifdef STARTUP_2BLINKS
if (modeIdx == 0)
Blink(2, 80); // power on with 2 Blinks
#endif
just how to get it to last memorized mode I cant find that easy
It is very simple, just download the files from oshpark, then upload them to oshstencil. Select the options you want and press order. They will be headed your way in a few days!
Thats not how I was charged or how they list their pricing on the site: https://www.oshstencils.com/ (click Pricing on the left).
I was charged between $2-$5 for mine. Although they do have a minimum order of $5 IIRC, so if you order less then that, it will still charge you $5.
That said, they are not the cheapest option for larger orders but they are simple, easy and fast. Just like oshpark. For larger orders there are much better options then oshpark but for small orders you can’t beat them.
Although if you know of another place that would be cheaper, go for it. Putting a bunch of different designs onto a single sheet could prove interesting.
Yeah reducing the capacitor to 0.33uF or lower helps to adjust the timing
Maybe add a 0.5, 0.33 and 0.2uF capacitor to all drivers of new batch, but most drivers are OTSM
Probably the 2S setting need always a reduced capacitor, I tested the 2S with a Triple and 4.2V power supply, so I missed that the 2S has a way too long timing with 1uF
OTSM fix this issue
Also hot driver messes up the timing if you are not using special temperature stable capacitors for 30-40 cents, but it has to be the a cutomized size to match the MCU to get the timing on all drivers the same
My two drivers what I talked about are 1s TA17-s and used them with clicky switch. One is in a triple xpl-hi flashlight and one is in a C8 with a single XP-L2.
Yeah it is living a hard life in a Convoy M1 driving a XHP50.2 at 9.8A on startup :smiling_imp:
So i cant blame it for being abit off hehe
Btw, have you changed the mode groups to something other then what is on the list in the OP?
I might be wrong but i can swear i set it to mode group 15 but i have 6 modes now and group 15 have 5 modes in the OP
Don’t forget that moon is counted separately from the rest of the modes, you can turn moon on or off in the menu. If you turn it off it should be correct.
The modes in the op should be right depending on what lexel used. I released a slightly revised version a few weeks ago I call V1.3. Mostly just minor changes that I think work a bit better in the real world after using it for a year. You can see the layout of the revised modes if you download the firmware zip file.
