I think there is wrong with blf gt, the BLF GT is 2500 lumen and throw further than 2000m,
D1S is not available with a shorty tube, so 18650 only.
Great list! I’ll add some of the mfg on your list that I missed!
I see that. Don’t know how I was using the Thrunite website but I missed the TN42 & TN40 which both have rechargeable options.
I haven’t included modded lights unfortunately. Too many, not consistently available and the market size just isn’t big enough to justify the time it would take to add them all
I’ll see if I can find them but neither Convoy or Sofirn has them listed on their official websites which is why I didn’t come across them yet.
Will look into this
According to Lumintops official website it’s 2000lm with 2000m throw
Specifications
Emitter: 12V Cree XHP35 High Intensity, mounted on copper DTP MCPCB
Flux: >2000 lm
Intensity: >1 Mcd (ANSI throw >2000 m)
Battery: Four or eight button-top 18650 cells
Driver: 35 W, 2.5 A regulated buck driver with conversion efficiency that exceeds 90%.
Ingress rating: IP65
Weight: Approximately 1.8 kg without cells
Dimensions: 135 mm Ø head x 315 mm length
http://www.lumintop.com/blfgt.html
Thanks, will correct
Thrunite has removed it from their website, but my good old TN32 still would not be out of place here.
No worries!,Fellow PA. resident. I am not perfect either! lol!
I want to sort this list by dollars per mm of head diameter, low to high ;)
Then, I mod.
Then, I mod.
BAM!
Your top 5 (all the rest are above $1.29):
BRAND | MODEL | LENGTH | HEAD DIAM |
WEIGHT | CELL TYPE |
CEL QTY |
EXT TUBE |
EXT QTY |
EMITTER | EM QTY |
CRI | LUMEN | CANDELA | THROW | MSRP | DEAL | DIAM | $ PER MM |
Sofirn | SP70 | 250mm | 90mm | 625g | 26650 | 2 | XHP70.2 6.25K CW | 1 | 5500 | 89733 | 687m | $62 | $50 | 90 | $0.69 | |||
Emisar | D1S | 127mm | 50mm | 151g | 18650 | 1 | XP-L HI V3 1A CW XP-L HI V2 3A NW XP-L HI V2 5D WW |
1 | 1300 | 130000 | 715m | $40 | 50 | $0.80 | ||||
Astrolux | FT03 | 170mm | 70mm | 295g | 26650 21700 18650 |
1 1 1 |
SST-40-W 6.5K CW SST-40-W 5K NW |
1 | 2400 2400 |
190000 190000 |
875m 875m |
$60 | 70 | $0.86 | ||||
Lumintop | GT mini | 132mm | 50mm | 150g | 18650 | 1 | 18350 | 1 | XP-L HI CW XP-L HI NW |
1 | 1200 1200 |
135000 135000 |
750m 750m |
$45 | 50 | $0.90 | ||
Sofirn | C8T | 144mm | 45mm | 140g | 18650 | 1 | XP-L HI 5.5K NW | 1 | 1310 | 500m | $41 | 45 | $0.91 |
Agreed. But I’ve chosen to start this list without including discontinued Flashlights. If I actually keep it up, in two years like 20% of the list won’t even be available for purchase anymore (other than used). That and I wanted at least as little work as I could manage an 80 item list lol :person_facepalming:
You missed the Lumintop GT70. Or is it on purpose?!
I should’ve remembered… lol BUT in my defense I just double checked and sure enough… Lumintop doesn’t have the GT70 listed on their website! :person_facepalming:
Well it’s already Friday. So things like that can happen I think.
Very nice list! Flashlight 10 on your list, the Astrolux MF04S, has a XHP70.2 not a XHP35 HI. Maybe you should add also the Astrolux MF02S with XHP70.2. You could as well add the Mateminco name in brackets to the Astrolux flashlights.
I really like the idea of a list with stock throwy lights because Enderman already has a list with modded mega thrower lights.
Thank you for the list. Maybe just check the links to each flashlight, as most of them point to the BLF GT
Very informative. Thank you.
I have a couple of lights, that if they don’t throw 500m,
I’m gonna throw ’em 20 meters to the canal.
a) Utorch UT02.
b) The other says Maeerxu M8. Believe it or not.
I bought it because it is a beautiful green.
I think is a copy of an Ultrafire model. Not sure.
Yes, I know Ultrafire means flashlight in Chinese.
Do these make the list?.
Also have a few HIDs that I’m sure can make the list.
Thank you for your effort.
Cheers.
P.S. Maybe the Trustfire R6 SST90 throws 500m?.
first your links are all leading to lumintop
second please use only measured values as Manufactorier like Niwalker or Astrolux lie on their specs, first lies like 70% morte throw than it has
91mm head diameter on the Niwalker 900k vs. TN42 100mm 600k really trustworthy?
Very nice list! :sunglasses: Flashlight 10 on your list, the Astrolux MF04S, has a XHP70.2 not a XHP35 HI. Maybe you should add also the Astrolux MF02S with XHP70.2. You could as well add the Mateminco name in brackets to the Astrolux flashlights.
I really like the idea of a list with stock throwy lights because Enderman already has a list with modded mega thrower lights. :smiling_imp:
Thanks for catching that, I will make the change and will check out Endermans list! :smiling_imp:
I’m gonna throw ’em 20 meters to the canal.a) Utorch UT02.
Yes, I know Ultrafire means flashlight in Chinese.Do these make the list?.
Cheers.
P.S. Maybe the Trustfire TR6 SST90 throws 500m?.
I will check all the lights you’ve mentioned but I’ve decided to keep this list to just LED for now. That may change when the upkeep on the damn thing isn’t so high and I end up with some spare time.
…. :rage: …. :weary: … :cry: … :person_facepalming:
I see that now… All of the links are 100% accurate and functioning in the back-up Excel file but it looks like when the rows are copied into the BLF table tool it for some reason chooses a single working link and decides: You go to BLF GT… You go to BLF GT… You go to BLF GT… You go to BLF GT… You go to BLF GT… lol looks like Oprah really likes the BLF GT!
That throws an incredible wrench into the works as the Excel back-up is where I make changes then abolish the entire table and re-create it with the Excel file. That way I don’t have to update two lists independently. I’ll have to do some testing to figure out a solution… for now I hope y’all really like visiting the BLF GT page! :innocent:
Yes I totally agree that mfg stated specs aren’t accurate. I do plan on adding a review link section and columns for reviewer tested Candela & Lumens…. It’s a little tricky because given the size of the list I don’t want to link/add every single review with results for each light but I haven’t ever seen a single reviewer who’s come close to the entirety of the list…
lol Yay for having overhauled the whole list the second day it was up and realizing you need to overhaul the damn thing all over again…. :weary:
there is still the physics you can calculate what an ideal light can get out of Reflector size and LED luminousity, then subtract the reflector and lens losses
also the max lumens of the XHP35 is known to be 2000-2400lm depending how hard it is driven
on the Niwalker light I would ignore the manufactory sprecs and list it with 2400lm and 500kcd which will be close to the real measurements and physics
or any manufactory could simple sell people a 10000lm xhp35 light with 50mm head and 2Mcd throw
also your list contains a lot of errors like
6 Niwalker BK-FA30S 178mm 76mm
it has a 100mm head
simply take the average of the review measutrements and its good
list only on trustworthy manufactories like Acebeam or Thrunite the ANSI specs because their lights usually are better than as they claim worst case that the light may have
also the max lumens of the XHP35 is known to be 2000-2400lm depending how hard it is drivenon the Niwalker light I would ignore the manufactory sprecs and list it with 2400lm and 500kcd which will be close to the real measurements and physics
:weary: I’m not sure of the equations used to perform those yet but will work my way around to it as I’d like to know it.
I definitely want to list both to expose manufacturers who blatantly lie or just don’t care enough to be accurate and to praise manufacturers who go to the hard work of making sure their numbers are accurate.
When I do add the test results columns it will include a percentage difference between the actual results and their claimed results.
The one major issue I’ve discovered so far is that nobody but Eagtac listed what they used for lumens. Eagtac advises LED lumens and ANSI lumens. It further complicates everything when hot rodders are likely stating OTF lumens on initial not ANSI…
Does the Sofirn SP70 need to be moved up now?
Hey matadors, have you tried to post an excel sheet in this site? I could on another site. When someone hit the link, it would ask to download the file.
Also, fooled around with Google sheets and posting on line.
BTW…I wanted to post a short list like yours on a different subject on a different site and couldn’t.
Sheesh….we got to be a computer scientist to post….lol
