The BLF Automotive Car LED headlights, results, opinions and beamshots!
I ordered a set of LED lights from evitek. They are the M1s in H4 and they arrived today. I will try them out when my wife leaves her car here for a while. I am putting them in a CRV. But opening the documentation says I may need to get a CANBUS adapter. Well that is not a real surprise.
Anyone else actually get these lights and put them in a CANBUS vehicle?
I also got a couple of spare fans. I will probably never need them, but they are cheap and not a month away if they fail.
I will post when I get them installed.
Put the Evitek M1 H4 LEDs in the wife’s CRV. We went out for a drive tonight to see how we feel about the LED lights.
Short answer - wow.
Whiter than some Halogens. Excellent beams. High and low. No flashing headlights from traffic (but it was a small sample).
The un-lighted area in front of the car seems to be longer on high beam. The immediate near range illumination in front of the car is moved further out from the car. But I think from reading about things that this is considered a good thing. I have sort of convinced my wife (the one that drives the CRV) that this is the way it should work. Low beam is just fine.
The Evitek bulbs seem to be a bit off the alignment of the light source vs the center point of the wide bulb tab. More research needed to decide if that is a feature or a problem. But it looks good. I will try to find a receptive wall and take some photos.
It appears it is OK for DRL. Again, a very small sample. CANBUS not upset on any settings.
I replaced a fairly new high output Halogen bulb with these lamps. The Halogen bulbs had been in there for a few months and were already showing burn marks on the envelope. Earlier I had found the Halogens I used to replace the OEM bulbs were literally burning through the envelope. Bulging and blackening the envelope.
I will try to find a site to do some photos. But these warrant your investigation. Hot wires may just have sounded the last hurrah.
Oh, and they are not particularly expensive.
Did you adjust the depth and rotation on the M1’s? You want to duplicate the factory beam pattern.
The H4s don’t have an adjustment. The H13, 9004, and 9007 do.
If they got everything right on assembly, an H4 should just fit.
I would not buy it if it was not adjustable. Why take the risk?
Two things.
First, they are installed in my car.
Second, regarding adjustment. If correctly manufactured to fit the light emitting profile of an H4 bulb, why would adjustments be necessary to put it in an H4 socket? And get correct alignment with the reflector built for an H4 bulb. I have never had a problem replacing H4 bulbs with more H4 bulbs. Although I have never tried crap LED lamps. Some of their other lamps have some adjustment points. I don’t know why they need them.
This particular light has a detachable metal H4 mounting ring. With appropriate H4 bits sticking sticking out in the right places. Then you put the rubber cap back on the headlight and push the lamp through the hole. It twists in the mounting hole and is firmly attached. This lets the lamp body seal, and clears the fan. I would have preferred no fan, but I will find out how well it will work. I bought a couple of spare fans just in case. They are easy to replace. There is no external electronics to run the lamp.
Without a real place to point the car and look, driving with them, it seems to be doing just what they say they will do. Being H4 lamps.
I believe there was a post somewhere above that has a link to a motorcycle site that I believe had some photos of the slightly older version of this lamp. And people were pretty happy with them.
Please verify the beam pattern and alignment are correct before driving around with them. This is part of being responsible. :+1:
The easiest way to do this is to put one stock bulb in and compare the beam shapes and height. Do a side by side comparison.
Just checking, can you guys see the pics?
This site might have changed their policies. I can’t tell.
Log in
x You must be logged-in to do that.
Well that sucks. I’ll try and repost it here.
Here is a repost that I had to rebuild from 2016. This is from a motorcycle forum about by 1986 Honda VFR700F2. It uses an H4 bulb and has a fluted glass front reflector.
Part 1:
Hello all, I just finished a headlight bulb upgrade using the latest 7th generation Philips Luxeon Lumiled ZES fanless H4 bulb. These are really great as they don’t use a fan, are very bright and maintain the correct beam pattern of the stock H4 bulb. They also turn on instantly with no warm up and flashing the high beams are instant. I bought a pair for about $66 USD. It would be nice to buy a single, but nobody sells them that way.
It uses 4 tiny led chips per side for low and the same for high. So that’s 8 total for low beam and 8 for high beam. They are 5w each so 40 watt total. When high is activated, low turns off, so it’s never more than 40 watts. These are positioned to duplicate the size, shape and location of the H4 filament. You can also see the shields on the low beam section. The base is also adjustable so you can rotate the bulb to get the best cutoff pattern.
They use a tiny little voltage regulator to work with 12 and 24 volt systems.
Part 2:
In order for me to get the perfect beam pattern I did a lot of fiddling around and trial and error. To save you guys some time, here is exactly where I adjusted mine to.
Here is the finished product with the rubber boot and heatsink screwed into place. There is plenty of room around it, although you probably need to unscrew the heatsink before installing and removing. I didn’t check to see if there is clearance to install with the heatsink in place, but I doubt it.
The little regulator box I fitted next to the turn signal relay making sure nothing touches the forks when turned.
Here are the beam patterns on a dark wood panel I had handy at about 8 feet away. This is about noon, but under some shade as it’s the best I could do at the time. We have the duller stock 55w/60w bulb and the new LED bulb, I’m sure you can tell which is which.
NOTE: (The new bulbs are brighter and the camera compensated by making the background darker. I adjusted the brightness to try and match the background of the stock bulb)
Finally a shot of the headlight to see the color. It’s a nice clean white.
I’ll follow up with some night shots and my impressions of them once I get a chance to go night riding. Hopefully in the next week or so.
BTW, I previously installed these bulbs in a 9007 size on my car. After a bit of customizing the rotation and depth I got a factory like cutoff and I was hugely impressed at the improved visibility, so I have a good feeling about these on the bike.
Part 3:
I was able to get some night shots just before dawn, but I didn’t really get to try them on some dark roads. So far they are great. There is a ton of light in front of the bike and the cutoff line is pretty sharp.
High beam is noticeably narrower and higher. I’m guessing that’s stock as I’ve never really noticed before.
BTW, this is a completely dark parking lot I found. The left and right look black in the photos, but it was actually a bit brighter. The headlight was also a bit brighter, but it’s hard for the camera to capture it.
I am not figuring out how to put JPEGs into the post. Can someone point me to instructions?
Here's a thread on how to post images on BLF:
https://budgetlightforum.com/t/-/47268
Thanks, I would not have thought of that.
Evitek M1 H4 lamps in a 2013 CRV
I am still not getting it. I made an album on Imgur. I posted it to the site.. But I still have not figured out how to get that information here.
I use the forums simple post editor, but that is up to you.
You should be able to just copy and paste the albums link. Then it takes you to imgur to see the pics. Is that what you want to do?
I individually linked each picture here to get the images to show here. Is that what you want to do?
I think there is a way to post an album here, but I can’t remember if that was with imgur or a different hosting site.
I have tried to download a post with multiple images. Nada.
Tried copying and pasting of the JPEG of a single image. Could not get it to size to the screen. The little box asking about sizing did not work.
This works, but you have to go look.
In general the lights look about the same in distribution as the Honda regular H4 bulbs. The distribution of the CRV reflectors is not so good. But the LEDs are significantly brighter and a nice pure white. My wife really likes them. We did a short nighttime drive and it did not seem to bother other drivers.
Cord
https://i.imgur.com/xvLVCEX
Base of lamp
https://imgur.com/DHpuEQ9
Fan
Imgur
Low beam
https://imgur.com/Fjp1Z0r
Lamp from side
https://imgur.com/AMAB8UZ
Low + fog lights
https://imgur.com/XscWhXb
High beam
Imgur
Cord
Base of lamp
Fan
Low beam
Lamp from side
Low + fog lights
High beam
Thanks Jason.
Anyone like to critique the light output? I would welcome some input.
Your two low beam pictures look very different.
The low beam plus fogs look to have a pretty sharp cutoff, but the other low beam picture looks like it has a really bad cutoff. I can’t figure this out.
Is your low beam pic really a high beam pic?
