+1
Bummer⦠This emitter is from a flashlight model that was vetted by the community here at BLF as genuine XP-E in the past, so I guess either the whole product is a clone, or the manufacturer started using fake emitters.
Many thanks for the help guys.
What is the flashlight brand & model?
SingFire SF-348.
I posted a new thread here asking for suggestions on flashlights with similar specs but a real CREE emitter.
If its a genuine SF-348 it should be a real Cree XP-E. (i have not seen one up close to have a look at the LED, as all i have is the BLF special edition ones with the Nichia 219 emitters in them. Maybe another member may be able to chime in on that one.
hi guys,
i have recently bought a bike Flash light that says that it Comes with two cree xm-l2 LEDs . After i read the forum i saw that mines are maybe fakes but didnt have seen any fakes that good. As you can see square contacts and the dots are more-pronounced.what do you Thing? are they real?!!
thanksā¦
It does look like a Latticebright XM2, (their copy of theXM-L2) I have a light with one in it and it has the same more-pronounced surface dots as the ones in your photo does. Though this version of the LB copy seems to be a bit better tinted than their fake copies of the XM-L, XP-G, XP-E emitters.
i think itās fake, but a good one, performance is not much lower than real one, not sure about the beam
i have recently found this thread. it Looks like that mines are the same. accordingly this one uses the chips from cree.
Cree never made XM-L2 emitters where there was phosphor on the bond wires & contacts like in that topic. (that looks even like a fake Latticbright fake with a very sloppy phosphor coating mess.
Dispute in Progressā¦
Check out this weird LED I found on the tool truck last week:
Click the second picture for full resolution.
Looks like another variant of a copy of an XP-E emitter.
Hi all,
I bought cheap āGENUINE XHP70ā led lamp from aliexpress (as starting point to my own project with XHP70). Here are pictures. Is this genuine led ? i donāt think so. Is it bright ? yes. Is it good ? I donāt know ![]()
It es neighter an XHP70 Nor an XHP70.2.
It is no known Cree-LED.
Definitely not a XHP70 (or 50) in any way. must be some kind of new knock-off, or just a odd-ball un-branded LED. The dies size look close to that of a CREE MC-E emitter, but its not one of those either.
i recieved genuine XHP70.2 XHP70B-00-0000-0D0BN40E5 from farnell. By comparing these two there are few major differences :
1) light emittors are up to 3 times bigger than chinese
2) ādomeā (i donāt know exact name) is not that clear as is on chinese copy
3) you can not see supply traces on support pcb
4) there is one dot and one rectangle instead one dot
5) there are almost invisible spaces between emittors. Chinese has huge gaps.
I am posting this question here because I didnāt want to create a separate thread just for this question. This emitter is from a genuine CREE spotlight, and I canāt find any information on it. My first impulse was to call it a CXA1603, but I canāt find any information on that emitter.
BTW, I once read somewhere a couple of years ago that CREE was planning on using non-CREE emitters is some of their light bulbs to keep cost down. So i suppose it is possible that this is a āfakeā CREE emitter in a genuine CREE light :confounded:
Does anyone know what this is
Looks like a Cree CMA series LED, similar to this: > https://ca.mouser.com/ProductDetail/Cree-Inc/CMA1840-0000-000N0H0A30G?qs=sGAEpiMZZMsl8UZd3ZuU6aAY3C3HMTrKC3ALTIlO%252boNGCTo7l2AB9A%3D%3D
DBSAR, thanks I had never heard of the CMA series
But this one doesnāt match up with any of those.
Diameter of the COB is 14mm while the metal substrate is 18mm. Measured voltage while running is 67.8V
Also they are calling this a high CRI light.
It would be interesting to see how far one of these can be pushed. As it is driven now it is rated at 850 lumen.
