even 0 ohm resistors have very little resistance, they put 000-ohm on this driver.
did you measured drive currents?
See L3 channel…
there are 4 resistors. because that channel under driven due to long track between FET & sense resistors.
this is why they put another resistor to balance. old buck driver SRK also have that issue.
Interesting, so maybe it would be good to check each channel’s output before signing off on it. Hope I remember to do that on the bench before assembly.
That one was not well balanced at all, stock it was like this:
L1+/L1- 2.20A
L2+/L2- 2.60A
L3+/L3- 2.08A
Power from 4x 18650 in parallel, checking output one channel at a time on the same LED (so it wasn't due to different LEDs having different Vfs causing the skew).
edit: and all 3 channels had the same 3x 1R0 + 1x 000
L3 channel has long track between resistors and FET. make it reduced output. to improve its current, solder thick copper wire to it.
other two channel difference is due to these sense resistors not 1% or 5% tolerance.
So it needs a jumper from the L3 sense resistors to the bottom left pin on the 7136? Would you leave the original PCB trace intact or sever it (would it make a difference)? L1 & L3 are good as-is, correct? And then mess around with the resistors to get the target output & balance the 3 sectors.
XML rated maximum drive current is 3A but some noticeable output improvement over 3A too. but after 6-7A difference is very small. so 6A to 11A no improvement at all. may be reduced output due to higher junction temperature.
