This question is like asking if I can add a horn to this specific model car. It doesn’t matter the year, make or model. It can be done. You just need some DC power.
You can tap a power wire into the middle of the driver where the red led wire is soldered. That’s battery power before the main led.
It looks like your switch has an on board location for a resistor. That’s good. It should use the same ground wire as the switch circuit.
So you’ll just need to add the one extra wire and resistor. Probably a 15k to 50k resistor. All very easy.
You can see how I added a switch led wire to my L6 here. I had to add an inline resistor, though.
It will draw power whenever the tail switch is on, but I don’t think that is a problem for you.
