Thought I would update this. I ordered the 18350 tube for the d4v2 from mtn hoping the threads would work out, and they did. Fits my d4v1 perfectly, and makes it scary tiny.
My favorite genre of movies are horror, and thriller/suspense types. As soon as a movie character pulls out a flashlight, I lose focus on the movie plot, and immediately start analyzing the torch. Does anybody else here do the same?
One thing that I have picked up on in movies, is when a modern day movie that is based on the past (1950s - 1990s for example), the flashlights are always really bright, and have a good amount of throw. Nothing like what flashlights were really like back in the day. I never picked up on this until I got into flashlights this year. LOL.
Wellp, watching old-timey teevee shows like âThe Saintâ , you can see what they had to do to get any light to show at all.
Eg, heâd pull out a penlight (wonderful how even Simon Templar EDCed a small light!) and shine around the room to try to find the hidden safe, etc. Someone off-screen would be shining a small spotlight around the room, trying to follow where Simon was shining his light. You could even see the eerie off-angle shadows being cast, but hey, that was high-tek back then.
My Lumintop FW3A arrived today. I only have one 18650 battery, and it is a Sofirn 3.7v 3000mAh button top (very small button at that, but never the lessâŚ). It works in the Sorfirn SP32A V2, of course, and it works in the Convoy C8+. So, I put it in the FW3A, and no go.
I read the owners manual and sure enough, an unprotected 18650 flat top with high drain (10A or more) is recommended. Ok fine, I have a Samsung 35E 18650 unprotected flat top battery scheduled to arrive tomorrow from the Liion store. Now I am learning a lesson about Li-ion batteries, so I go online to double check what exactly I ordered. Yep, it is a unprotected flat top 18650 battery, but it states it is only 8A, but also says up to 13A manufacturer pulse rating. Another problem I just caught was the SAMSUNG 35E is not recommended for high drain devices, and it measures a length of 65.3 mm, and the Lumintop manuals says the maximum supported length is 65 mm.
Question: Can I use the Samsung 35E in the Lumintop? Or did I just learn an expensive lesson in li-ion batteries.
I am currently using 35Eâs in 8 different FW3âs, so yes, you might get a little more output from a 30Q but not for very long as it will heat up very fast and step down.
The Sofirn should work, it just may not hold up to turbo. Unless youâre saying it didnât fit?
The 35E should be fine, though Iâd personally recommend a 30Q.
The Samsung 35E is perfect for this light. 35E, LG MJ-1 and Sanyo GA are the perfect top three. The extra capacity is impressive, and there is no chance your eyes will notice any difference in brightness vs a higher drain, lower capacity cell. Exxellent choice.
I think the one thing your missing is that the FW3A manual just doesnât go into enough detail. It should say something like âunprotected 18650 flat top with high drain (10A or more) is recommended for maximum outputâ.
The reason the 35E is not recommended for high drain devices is itâs chemical mix is optimized for max capacity. This means itâs internal resistance is a bit higher than say a âhigh drainâ cell so it wonât pull as many amps. You can read more about battery ratings on this older post and the one below it.
Hi guys, I have a question regarding flashing firmware. I am about to flash my Astrolux MF01 mini to correct some voltage reading problems and founf myself at deadend. I managed to find some instruction from toykeeper and I did this:
I downloaded the branch âlp:~toykeeper/flashlight-firmware/fsmâ from: Flashlight Firmware Repository in Launchpad because it had the code for Astrolux/Mateminco MF01 MINI. I Unzipped the tarball and found the file I needed to adjust to correct the Voltage measurement:
Now that I have it, how do I run the make command in the fsm\ToyKeeper\spaghetti-monster\anduril folder?
Do I need a special compiler (I am using windows)? The instructions I found said: âthe code can then be built by going into the anduril directory and running âmakeâ. This compiles one .hex file for each cfg-*.h file it finds.â
I dont know if this is the best place for a flashing question. I would also ask on a thread that talks about flashing drivers. Your more likely to get your answer.
