Yes, there you go. The battery tube needs to push the carrier against the driver to get both positive and negative to make contact. You would need to add a spacer to the X65 tail cap to push it forward more. Maybe some foam or cardboard will work.
This is in my X65vn MINI.I am thinking of getting Molicel P26A/VTC5D as second set of batteries which are much, much better than 30Q/VTC6 or MJ1 on HKJ voltage curve at 15amp and 20 amps.
You rarely see them used with FET drivers. With a Buck driver like in the GT itās set to 2.5A Turbo. The Boost driver in the MF04 is maybe 2.7A, but that is pushing it. Most drivers limit it to 1.8 to 2 amp. More amperage only gives a tiny bit more output, but a lot more heat.
I donāt know what driver design the X65 mini has, but if the carrier is 12v, then itās probably a Buck driver. I would guess itās no more than 2A per led, so maybe 10A draw on Turbo.
If you want more non consecutive Turbo runs, a high drain battery will work well. You donāt want a lot of voltage sag at 10A.
This is Not stock anymore. It is X65vn MINI. I heard he uses FET drivers from Richard. Not sure if it is in all of his lights.
In my type A analyzing brain I try to find the best combo of amp draw and run time. The re wrap VTC6[Acebeam batteries ] do pretty good. MJ1 higher incremental voltages but less output, which probably is not noticeable. Basically getting 15 minutes of turbo in 3 minute increments.
P26A would probably be 12 or 13 but more output. It is crazy how powerful the light is. Eating up 4 X 18650 on turbo in 15 minutes!
Okay, so you have the X65vn Mini from Skylumen? I donāt know what driver it has then. Might be FET. Best thing to do is ask Vin what battery to use. He is the one that knows.
(I thought you had the stock light and was thinking of sending it to Skylumen)
No,I will use P26A for spares, second run. The only way to know there run time versus other batts is to get them. I know they will provide plenty of amps.
Here was my run[post] for tonight:
I picked the best setting for me. 1%/30% and 100%
It was 58F out tonight. Initial burst was for 5.5 minutes on turbo. Then a few minutes on 1% to cool down, then 30%[which is ~3200L] for several minutes where it wonāt get hot, then back to 100%ā¦ā¦ā¦ā¦repeat cycle! :+1:
Iāve used my brotherās rotary tool to first cut then sand down small pieces of metal into even smaller ones a couple of times recently.
F.e. I made a couple of 10 mm MCPCBs from 20 mm ones.
Now I need to do it again, reducing 20x20 mm copper piece to about 8 mm in diameter.
So far I kept the work piece in my fingers. It was not safe and I donāt want to do it like this any more.
I tried pliers but since the jaws are not parallel, they grip only the edge and the work piece rotates.
I tried pliers with some paper, it was a little better - but only a little.
I considered vice but:
it makes cooling harder
I canāt clamp it in the room that is the easiest to clean - bathroom
Can anyone give me suggestions how to do it safely and conveniently?
I used a piece of paper-and-bubblewrap envelope to protect the MCPCBs. Plastic + paper turned out to be adequate soft jaws material. Though not very durable due to water softening the paper.
Those Knipex at $53 discounted are a big investment, but might be worth buying if I had other uses. But they look like a smooth finish jaw so not sure if they can hold the MCPCB very well.
I got a few locking pliers types, but again not sure bout the teeth and adding cushioning. Some have teeth that are too big, or deep teeth that are hard to cushion. I'll have to see.
We call tongue and groove pliers āChannel Locksā and locking pliers āVice Grips,ā though that might not be the real names. Never heard them called anything else, but a rose by any name would smell as sweet.
