It is relatively easy to unsolder the two wires from the mcpcb and swap in a new mcpcb that has your new leds installed. This mainly comes down to whether you can buy the leds you want on a mcpcb that fits. This has the advantage of changing the led footprint such as swapping from 3535 to a 5050 led.
If you cannot get a loaded mcpcb then you are limited to reusing the stock one. This means your new leds have to be the same footprint and you have reflow solder it. This is much more complicated and usually requires a hot air station or a hot plate. Itâs a more advanced technique.
So you have to do your research and look for the parts you need. In the US, Mountain Electronics is a good source of leds already reflowed onto mcpcb. He can mix and match whatever he has in stock. Otherwise youâll have to find a preloaded mcpcb probably from overseas.
Itâs definitely smarter and cheaper to buy a solder iron and learn the basics yourself. Then you can at least swap parts and fix wire connections, etc⌠Having to ship lights to people for simple swaps can get very expensive, be time consuming and you risk a package being lost or damaged in the mail.
I think itâs also worth investing in a test LED for trial and error reflowing. One you would not care for breaking in a cheap light. Also find some junk electronics and have at it with the soldering iron to learn. Just make sure itâs unplugged and there is no battery with what you are working with.
Will the Sofirn SP36 BLF ever get Anduril 2 from the factory? I am a bit of a newb and donât want to attempt to flash anything myself unless there was a dedicated flashing port, etc. I have Anduril 2 in the BLF LT1 and the Wurrkos TS21 and I am looking to continue with that as opposed to trying to learn Anduril 1 at the same time. Thanks!
Only Sofirn can answer that. They probably buy the drivers in batches so they may have hundreds still on hand. If they get low they may order the next batch with Anduril 2. In order to do that they would need at least one of their software employees to rewrite the code for this older light instead of writing code for newer lights. Or they would have to pay Toykeeper a fee to modify the code. They may not want to spend the money on an older light. So it seems unlikely they would do that.
If the light is still selling well, Anduril 2 becomes highly asked for and they donât have a new light being designed to replace the SP36 - then they might upgrade it.
My guess is it would be unlikely to happen. You might sending an email to Sofirn to see if they know.
As the year 2021 is ending, I wonder what will happen to those unsold 2021 flashlights. I think they will not be able to compete with newer, better-designed, and possibly cheaper flashlights of 2022.
And what has happened to those old stocks of 2020 and 2019?
Same as any other product. They will sit in a box until its sold. If sales slow down they will go on sale. Eventually it will get sold. This is why they are built in batch sizes based on how they are selling.
Yeah, my cut off range would be closer to 4 or 5 years. Even then, there might be a cool design thatâs really old that can be modded. Or you might find a low powered light known for its nice color and tint and it fits your needs. Why not buy it? So thereâs way more factors involved than just age.
How do you guyâs characterize beam profile? I understand terms like flood and thrower, but was wondering if there are some more quantitative definitions. Do you define angular beam spread by the contour of 50% max luminance, 50% encircled flux, or just what kinda looks good?
A more down-in-the-weeds geeky question: When posting beam shots do you use conventional JPEG imagery which converts detected luminance values to display levels using a nonlinear factor (gamma) that reflects human visual response or do you see some value in using linear RAW conversion (gamma=1.0) which produces output levels accurately reflecting the actual luminance detected? Iâve done beam shots both ways and the results differ markedly in appearance.
Iâve only been at this game of characterizing lights for a short while and donât want to spend a lot of time figuring out issues which you guys settled years ago.
I donât âcharacteriseâ them except descriptively. Eg, a beam can be âringyâ (rings or just a âbullseyeâ pattern), can have a nasty corona around the hotspot, can be âfried-eggyâ (blue spill, yellow hotspot), have a âcloverleafâ corona/spill, etc.
Or just âNoice!â or âEww.â.
Some people do go all-out with snapshots of the beam, put little âxâes in various places and show the color temp at each spot, etc., but thatâs beyond my ken, and my barbie.
Basically, the settings you see are the upper limits of measurement. They are multiples of 2s times 10 to some power. On the left are DC measurements, the right are AC measurements. So to left would be the 1000 Volts (âcause it isnât rated for higher isolation/components), 200, 20, 2 (which they represent as 2000 millivolts) and lastly the 0.2 (200 millivolts). The same would go for the AC scales (only two are available for common voltages).
Below the DC volts are the resistance settings. Never to be used in a live circuit. Either blow the internal fuse, but this model would fry the insides. On the right are the Amps (current) drawn. Only DC measurements and you need to switch the black red lead to the â10 Aâ hole*. Below that is the frequency and the diode (continuity) test. That last one may have an audible sound when the circuit is below some set value â usually less than 1 Ohm. Frequency is on live circuits (like household plugs and receptacles), the diode test is a resistance test, done on NOT live circuitry.
*edit. Strange they have the 10A receptacle in black. I stand corrected.
Never worked with series and parallel circuits I presume. Youâll need some beginnerâs guide on how to make measurements of voltage and current.
I hope you didnât pay much. If you are a beginner, most probably will make the common mistake of turning the switch when plugged into some live circuit and WILL burn your device. That is why these things are still sold, for beginners and not too expensive.
The V~ is your AC (alternating current) like in your house.
The V-⌠is your DC (direct current) like in a battery.
The different numbers are just the max ranges. You could measure the battery voltage at 1000 volts, but you wonât have enough accuracy.
The 2000m is 2000 millivolts (or 2 volts). Thats not enough for your battery so 20 volts is the best option.
The horseshoe is Omega or ohms. That measures resistance.
The A is DC amperage. You have to be careful using this. Or at least the 10 amp setting which requires you to move the red probe to that other port. Try not to use that at all and leave your probes in their current positions.
I would have recommended a different DMM. One that auto ranges and auto turns off. This one looks like to have to remember to turn it off manually. If not, youâll run the battery down and that sucks.
And a loose driver causing flickering. Either thinner PCB (1.5mm versus 1.6mm) or something making partial contact on the driver rim whose retainer cavity isnât threaded all the way down (intermittent contact when screwed down).
Did you get that fixed? A series of unfortunate eventsâŚ
Measure voltage across the 2 live points. Amps measured in between the test circuit. Thatâs to say it is part of the line circuitry.
As for the cells, they may come back alive. Depends on your charger. The simple ones donât usually bring back up, but you could try anyways. Just monitor the led status and check periodically if they take a charge. Some chargers will detect lower voltage and trickle charge to 3 or so volts. They use about 100mA to smoothly get the cell up. But some cheaper chargers also only charge at about that rate (200 to 500 mA, or .2 to 1/2 Amp). Then again these are 10180 cells, like the smallest of LiIons. Jason will chime in, but I think 100 mA may be too much for such a small cell. They would heat up if dendrites formed.
Test them with caution in your charger. You feel any heat, disconnect. Theyâre no good.
Not all lights have Low Voltage Protection (LVP), so Iâve taken to charge my light after every use. Sometimes my charger says they are near full, but often they need some fuel.
Well, trash these if you have spares and can get more.
That parasitic drain is also a problem across some lights. Periodically I check some of my lights that donât disconnect via the tailcap quarter turn. Some I remove the cell.
The 2.09v one is dead. Roughly 2.5v is the cutoff on li-ion cells before serious damage occurs.
You can try charging the 2.45v one and see what happens. Check it after 20-30 minutes and see if the voltage is higher and if its warm or hot. Typically if its damaged it will never get to max voltage. It will sit at a lower voltage forever and get quite hot in the charger. If this seems to happen, Iâd consider it damaged and get rid of it.
Searched around a little for some good tutorialsâŚman thereâs a lot of junk info out there. Here are a couple good videos and articles that should help you. Nuts and bolts stuff for using meters and basic tests, but it would pay to check out some of the basic conceptual stuff about electricity in general. Youâve already got some letters in the alphabet soup, so itâll get easier as you gain some more and understanding falls into place. Itâs a lot easier to learn hands-on with someone showing you, but videos can take the place of that sometimes and there are tons of âmakersâ around these days with content (and sites like Adafruit and such have a little bitâŚthese links seemed better to me, though).
This is good and kinda gets straight to the point for you with batteries, then really basic LED circuits (like stuff you might do modding an ultra cheap flashlight that doesnât have much in the way of a driver to control things). Could be the best seventeen minutes of your life: https://www.youtube.com/watch?v=ts0EVc9vXcs
This channel - âThe Engineering Mindsetâ - is really excellent. Heâs done a marvelous job illustrating concepts for general stuff, components, and circuits (and other things) and presents them in a way that is easy to grasp. I found that channel while searching for things about neutral lines (A/C) and some hvac stuff, then saw how many great videos he has. He doesnât have a good one for basic multimeters but there is this one on battery testing. He shows the correct way to test cells with a small load applied (resistor) so that you can see if a cell is behaving nicely rather than just looking at voltage alone. This isnât really necessary for our li-ion flashlight batteries but it can be important for lithium primaries (coin cells, etc), silver oxide, alkalines. He does have lots of individual videos covering the basics like voltage and current and resistance and inductance, etc., and when you feel like it those would probably be very helpful for you. But using your meter for the basic nuts and bolts you donât necessarily need to know all of that. If you search his vids for âmultimeterâ most of those will come up close to the top of the list.
HOWEVERâŚ.safety is important, and other than remembering not to short things out accidentally, I have to mention that our DC low-voltage flashlight circuits and most things on circuit boards and components are generally pretty safe. When you move over to equipment like motors and air conditioners and automotive, you really need to know more about what youâre doing and how those things are assembled, and proper testing procedures for them. There are chances for a nasty shock (larger batteries or current, larger capacitors, etc), and also bigger potential to damage parts (mechanical and electrical bothâŚor your meter).
And a couple good articles with some of the same info plus a little more explanation of the settings/symbols on the meter:
All that said, other things you should know about your meter. First is that they need a fresh, strong battery inside. The battery is the power source for most testsâŚit feeds energy into a little circuit which the meter uses to determine voltage measurements and if the battery gets low and canât provide enough juice, your readings may get very inaccurate or shift around as you watch the screen. This can happen before any âlow batteryâ symbol appears on the screen. So always remember to turn it off and keep the battery fresh.
The test leads with that meter are on the fragile side of life, so be gentle with themâŚthatâs true for both ends of the leads. Usually the nickled pointed probes that go back into the handles do not have a good design for connecting the wire, and the wires are roughly solder right onto themâŚand those wires are usually pretty tiny and poorer quality, too, so theyâre easy to break just by bending or may break or come loose with a little tugging. If you want to wrap the leads around the unit for storage, donât do it tightly. You can get replacement leads (actually those same leads are often like $0.40 on aliexpressâŚmaybe $5 if you were to find them in a retail store), but for a freebie and for a cheap meter, it would make more sense just to buy a new slightly nicer meter instead. Of course you can try to fix broken leads, too.
Back to safety. Although this meter will do some A/C basics, itâs really not a great or safe meter for that, in my and most othersâ opinions on these. So if you want to check outlets and cords or lamp sockets and such, just be sure you understand what youâre doing so you donât pop a breaker or scorch something, blow the meter fuse/meter itself, etc. These are best for simple checks on low volt electronics and such, and they do ok there.
Safety and probesâŚâŚfor flashlights and whatnot, it doesnât matter if your skin is touching the probe tips or wires, components, etc. But do get in the habit of avoiding that whenever possible, and keeping fingertips behind the little protective circle disk things on the probes so skin doesnât contact them or circuitsâŚitâs just wise. With high powered circuits and with A/C there can be a potential of arcing in some situations, so keeping skin back and touching only insulation is a good habit (and in those cases, better leads are really required). Also a good habit to try and honor polarity (red/positive to positive and black/common/negative to negative)âŚfor many functions the meter will handle it either way without worry but sometimes it does matter and sometimes itâs unsafe to reverse them (for things like diodes/leds itâs kind of mandatory to test operating function but you also check those in both directions/polarity anyway).
When using the leads, remember that firm contact makes a good connection, so press them lightly into the metal of terminals/legs/solder joints, or in the case of bare wire (with flashlights) you can squeeze the wire to the probes with fingers. If you just let the probes barely touch the contacts, sometimes youâll get inaccurate or wandering readings, and some batteries have coatings on them that you need to get through (or oxidation, even if they look clean). You donât have to press hard, just firm, and remember that these leads are kinda fragile. Also, wipe off the leads before you use themâŚa little alcohol once in awhileâŚjust like flashlight threads, any grease or grime there may interfere with good contact.
Anyway, glad you got a meter! Should put your mind at ease and it can be fun to look deeper into your stuff. Itâs interesting to see how cells bounce back up a little in voltage after the load is removed from themâŚsome bounce back faster or more than others. You can check out tailcamp current (amps) for many of your flashlights, tooâŚeven if thatâs not the most accurate/truth (vs current at the emitter itself) you can get a good idea of the power and can also compare different batteriesâ delivery.
