the Fasttech one also required reduction to 19mm btw :-) , it seems like they were never meant to be used with a 20mm board (assuming anyone out there has spend a single thought on the design of these things)
Are there any c12 host that uses a xre reflector? and how well does a xml reflector work with a xpg?
I have a spare dedomed xpg2 on a sinkpad so i may put it in a c8 style host too
In design/shape terms I still can not imagine how a reflector can be specific for a led other than that is has a hole big enough for it. In other words: a parabole is a parabole is a parabole, right? Perhaps the 'XR-E' reflector happens to be a better made one?
They are totally different shapes. XML is narrow at the base, the side walls are right up against the opening. The XRE has a large, ~14mm flat area around the hole. Wider at the bottom and the same size at the front means the wall angles are closer to parallel.
I thought I read that most c8 pills will fit most c8 but the xintd c8 wasn’t compatible
XinTD pill threads are the same as the generic C8, it's the Convoy that's the oddball.
thank you. I couldn’t remember and I am also trying to decide on parts/host for my first c8
Just to add to the confusion, XinTD and Convoy battery tube/tailcap threads are the same, and different than the other generic C8s.
Here is what have I picked so far:
host:
http://www.fasttech.com/products/1562701
reflector:
http://www.fasttech.com/products/1575100
(This is the 41.5mm wide one, there is also a 42mm one, which to choose?)
Driver:
http://intl-outdoor.com/qlite-reva-71358-multiple-modes-circuit-board-304a-p-710.html
LED:
http://intl-outdoor.com/noctigon-xp20-mcpcb-cree-xpg2-s2-2b-led-p-788.html
And a brass pill:
http://www.gearbest.com/diy-parts-and-tools/pp_27445.html
Am I missing anything? Or would you suggest something better?
I think you need to scroll down on that page and read the review that's been posted there.
I did missed that… is better to swich the host or to find new pill?
Brass pill, more expensive one, and the only I can find (was suggested here earlier)
Can anyone comfirm that one fits?
You can use the Convoy host, just swap the stock reflector for an XR-E one. And use the empty brass pill that fits the Convoy.
Or... http://intl-outdoor.com/xintd-c8-v5-xpg2-s2-multioption-18650-flashlight-p-789.html
Xintd C8 is a good suggestion.
Hhh , thanx, I will go with the convoy host then
I have orderd as listed above, jus with the Convoy host. Hopefully didnt miss something again
As I understand, the driver is now 2mm thiner than the pill, so should fitt in fine.
Just a question, should I use thermal greese with it? (on the emitter side, or maybe both?)
Just get the XinTD C8 with the XP-G2 S2 stock, I think it will be cheaper, alot easier and better.
Sure, but it takes away the fun of putting it together and probably melt some parts in the process
^lol. nothing like a package arriving and thinking you’re gonna have a light haha
Yes waiting for the post snail* to come along
- a phrase from the forum, just giving a credit, sorry cant remember the user nick. Digging it though
