Oh, yes, I know what you are talking about…
My firmware-flashing hardware finally showed up yesterday (package had been lost), so I can actually try modding the bits on an attiny now. I still have to figure out how to get it all working in Linux (seems most of the info online is for Windows), and I’m still short on time due to other projects, but I expect I’ll be very interested in trying the new firmware soon.
Any hints for a good setup for testing firmware? I should have an empty Convoy S2 host showing up today and was planning to use the tail end as an 18650 tube for my RRT01, which leaves the head available… could probably just assemble the head normally except for having long wires to an exposed driver, then simply hold a couple extra wires up to a battery to simulate clicky button presses.
That's exactly how i have been doing it. Or actually I have been using S2+. :)
I have thought of building a better driver test station, but not yet, as the S2+ with longer leads works well enough..
I have been flashing the driver so many times that my Pomona SOIC clip starts to wear out. Have to fiddle it and hold it tight to get a working connection.
Any hints for a better SOIC 8 clip / pointers to where to buy?
By duty cycles you mean time on and time off? If so then you are a genius… ’cus I wondered the same thing. If 10 or 12 Hz is great but the off time allows for the officer to be surprised then why not increase the on time and find the sweet spot.
Yes. As explained by this pic (borrowed from Wikipedia article):
The duty cycle is defined as the ratio between the pulse duration () and the period () of a rectangular waveform.
[quote=scottyhazzard] If so then you are a genius... 'cus I wondered the same thing. If 10 or 12 Hz is great but the off time allows for the officer to be surprised then why not increase the on time and find the sweet spot. [/quote]
That's what I thought, adjusting the duty cycle up during lower frequencies of altering strobe would further reduce the unwanted effects.
But so far I haven't been able to find the sweet spot.. More experimenting is definitely needed.
I’m pleased to hear you are working on this, this is great.
Thanks, I got everything set up and working. It gives me a warning about setting the sck period and then can’t verify the firmware after flashing, but it otherwise seems to work.
If you have a hex file and/or source code file to try, I’d be happy to test it out. Additionally, I’d like to add it to my firmware repository if possible.
Er, I’m not 100% sure that my build toolchain is creating the same hex files as other people, so I’d prefer to get a hex file in addition to the source code, instead of just the source. I think my gcc might be creating files slightly larger than what other people are getting.
Thanks, I got everything set up and working. It gives me a warning about setting the sck period and then can’t verify the firmware after flashing, but it otherwise seems to work. If you have a hex file and/or source code file to try, I’d be happy to test it out. Additionally, I’d like to add it to my firmware repository if possible. Er, I’m not 100% sure that my build toolchain is creating the same hex files as other people, so I’d prefer to get a hex file in addition to the source code, instead of just the source. I think my gcc might be creating files slightly larger than what other people are getting.
Good to hear you got it working! Please PM me your email address and I'll send you the .hex file of the latest test version (v08).
Regarding to the size, please check that you have the -Os flag set (Optimize for size).
Thanks. I’ve been using -Os to optimize for size, but when I tried building STAR with on-time memory, it still came out about 30 bytes too big. Looks like I might have an old version though, since my avr-gcc is 4.7.2. I can try to get something newer and re-check the size, but so far I just grabbed whatever was in my distro (and I need to upgrade that sometime too).
So… interesting. My initial observations:
- The fast PWM is nice. I can barely see it in my PWM test, and don’t notice it at all during regular use.
- The way the mode memory works is interesting, and may not be obvious at first. It can take almost three cycles through the main modes before the “hidden” ones are accessible, and the counter resets each time the light is left on more than a second or two. So, it acts like it has just the normal modes unless you cycle quickly through them two (or three) times to reach a hidden mode. After being on for a couple seconds it’s possible to advance directly to the next mode during the regular modes, but not in the hidden modes. (so, medium mode, wait, tap-tap the button, and it’ll go to high mode… but first beacon, wait, tap-tap, and it goes to low or low-low instead of the second beacon) This lets one skip the other hidden modes, but getting back down to a lower regular mode requires cycling through the rest of the regular modes.
- The lowlow mode doesn’t actually light up my emitter at all. I’m using a XM-L T6 0A or similar emitter (from some cheap old light) on a 8x7135 3.04A qlite driver. Whatever setting it’s at is apparently too low for this hardware.
- The strobe is quite obnoxious. I think that’s kind of the point though. It seems to heat up the head of the light too, but that’s expected since it’s a 50% duty cycle with 3A, and 1.5A is plenty to warm up a small host. I’m not really into tactical strobes though, so it’s hard for me to say whether this is good overall. I prefer low-duty-cycle motion-freezing strobes.
- The two beacon modes with a background light level are nice. I might prefer something less bright though, for both the background and the flash.
- The no-background beacon could probably use a much, much shorter duty cycle. Like 1ms or so. Depends on if it’s designed for locating the light in the dark (very very short pulse) or signalling to people far away (current duty cycle seems appropriate).
- Not sure why there is both a SOS and an alpine distress beacon. In general though, I’d go for a faster SOS.
I haven’t tried the stars. I don’t really want to solder the stars on my test driver, and pencil hasn’t worked.
Thanks for these! Good input for further development. :)
[quote=ToyKeeper] * The way the mode memory works is interesting, and may not be obvious at first. It can take almost three cycles through the main modes before the "hidden" ones are accessible, and the counter resets each time the light is left on more than a second or two. So, it acts like it has just the normal modes unless you cycle quickly through them two (or three) times to reach a hidden mode. After being on for a couple seconds it's possible to advance directly to the next mode during the regular modes, but not in the hidden modes. (so, medium mode, wait, tap-tap the button, and it'll go to high mode... but first beacon, wait, tap-tap, and it goes to low or low-low instead of the second beacon) This lets one skip the other hidden modes, but getting back down to a lower regular mode requires cycling through the rest of the regular modes. [/quote]
Yes. That's the original idea of this FW: Combination of normal memory (normal modes) and short cycle memory (hidden modes).
To avoid accessing hidden modes accidentally, you need to have six continuous clicks and go over the last normal mode (= turbo or low, based on stars).
[quote=ToyKeeper] * The lowlow mode doesn't actually light up my emitter at all. I'm using a XM-L T6 0A or similar emitter (from some cheap old light) on a 8x7135 3.04A qlite driver. Whatever setting it's at is apparently too low for this hardware. [/quote]
Hmm.. Weird. The lowlow is PWM 7 in v08. 7 has been reliable in my tests, but I have tested only with XM-L2s.. 5 didn't light up most of them, 6 did light most but not all -> 7 has lighted all emitters I have tested (and it's already quite high for lowlow, I would like to use 6 if that would be reliable..)
[quote=ToyKeeper] * The strobe is quite obnoxious. I think that's kind of the point though. It seems to heat up the head of the light too, but that's expected since it's a 50% duty cycle with 3A, and 1.5A is plenty to warm up a small host. I'm not really into tactical strobes though, so it's hard for me to say whether this is good overall. I prefer low-duty-cycle motion-freezing strobes. [/quote]
The strobe in v08 is (pseudo) randomly alternating between 13 and 19.5Hz, with 40-60% duty cycle. Those values seem to work quite well: very disorienting, still enabling to notice opponent's movements. Having another low duty cycle, lower frequency motion freezing strobe is still an option.. Let's see.
[quote=ToyKeeper] * The two beacon modes with a background light level are nice. I might prefer something less bright though, for both the background and the flash. [/quote]
I have been thinking of having another of those with lower level, and the other with higher. Further experimenting is definitely needed.
[quote=ToyKeeper] * The no-background beacon could probably use a much, much shorter duty cycle. Like 1ms or so. Depends on if it's designed for locating the light in the dark (very very short pulse) or signalling to people far away (current duty cycle seems appropriate). [/quote]
Good idea, but not down to 1ms. Maybe 10-20ms instead of the current 50ms.
[quote=ToyKeeper] * Not sure why there is both a SOS and an alpine distress beacon. In general though, I'd go for a faster SOS. [/quote]
Both have their uses, and as they are at the end of hidden modes, they won't harm anyone.
Faster SOS? The strobe timing is still a bit off in v08, but I was thinking of fixing the timing and also making it a bit slower.
[quote=ToyKeeper] I haven't tried the stars. I don't really want to solder the stars on my test driver, and pencil hasn't worked. [/quote]
You may want to try softer pencil and more strokes. It works well in my tests.
Hmm… Weird. The lowlow is PWM 7 in v08. 7 has been reliable in my tests, but I have tested only with XM-L2s… 5 didn’t light up most of them, 6 did light most but not all -> 7 has lighted all emitters I have tested (and it’s already quite high for lowlow, I would like to use 6 if that would be reliable…)
I found that 8 made a decent 0.05 to 0.25 lumen moon mode on this host, and 9 gets about 0.5 lm to 1.4 lm. But I’m using a junky old XM-L 0* tint of unknown bin, just because I knew I probably wouldn’t ever use it for anything else.
(beacon w/ background)I have been thinking of having another of those with lower level, and the other with higher. … (beacon w/out background shorter cycle) Good idea, but not down to 1ms. Maybe 10-20ms instead of the current 50ms.
If you’re curious, I have several levels of beacon-with-background in the firmware I wrote today, and also a beacon-without-background which works reasonably well with only a 1ms or 2ms duty cycle. The latest build is here if you’d like to try it:
http://toykeeper.net/tmp/tail-light.hex
Moon, low, med, high, higher, moon-low flasher, low-med flasher, med-high flasher, high-higher-flasher, heartbeat beacon.
Beacon with a background? Is that a low level light with a flash?
Yes. Didn't come up with a better name for it..
I have used the 4 mode version of v09 a little. Feedback so far is:
- Absolutely love the mode separation. Perfect. Moonlight level is perfect in the house with my dark adjusted vision. Really, just perfect.
- Seems like only one or 2 blinky modes should exist as you can only get to one at a time. So you have to do 9 half clicks to get to one. If its not the one you want you need to do 9 or 10 more to get to the next blicky mode.
Thanks for the feedback!
The idea of this FW is to provide ease of use of a normal 3 (or 4) mode light, still providing some extra modes for occasional use. The blinky modes are well hidden on purpose, so that they won't harm normal use. On the other hand, having many extra blinky modes don't harm either, because they are not in the cycle. Only the order of blinky modes matters => 2 most often used shall be the first ones..
Number of clicks required to enter the "blinky mode zone" is less in 3-mode driver. Would you please try it out?
The more I use the 3-mode version, the more I like it. I have it now also in my S2+, in which I originally used the 4-mode version. L-M-T are good for most use, and the hidden lowlow can be found every night as the first hidden mode. The light can then be used during the night on lowlow, as it's remembered just like the other modes.
I’m liking this UI better and better the more I learn about it.
I don't mind 9 clicks to get to a hidden mode. It's having to take multiple trips to get to a specific blinky mode, but I didn't realize about the 2 most common blinkies being first.
So the FW will generally take you to the first blinky mode after a certain amount of time passes? I will pay attention to that and reevaluate. I think the modes I was getting were a strobe mode and a beacon type mode. Those do seem like good modes for the first 2 modes.
Not sure when I will get a chance to flash the 3 mode version. It takes me time to set up to flash and time is pretty limited for me right now.
I just lashed v0.9 turbo 1.4a on my hotrod s2, with 8x7135, and T6-3C.
first impressions:
Moon is sufficient, pwm is noticeable. Turbo gets almost to hot before timing out in my s2 8x1735(2 min)
The background for the beacons is to high imho, when using a cone beaon is not that well visible. (it aint pitch black here tough)
i don’t think beacon should be lower lumens.
didn’t try it at night but the 1 sec beacon is pretty fast imho, maybe go to 1.5 - 2 sec ?
Tomorrow i’ll make a p60 drop in, on a 5x 7135 based nanjg 105c , thats my favorite nanjg, well balanced i think between lumens, heat and runtimes.
Edit- i see there is difference between star 2 and star 2&4 connected, is it possible to do something for the turbo dropdown value and timer with star 2 and 3 three connected ?
