The area where the tape would go, above the MCPCB and under the lens, about how hot does it get there?
3M 6900 Photoluminescent Film Product Bulletin, August 2015 shows:
Service temperature range:
–30°F to 200°F (–34°C to 90°)
Would I be good to go within this range?
Finally got my hands on my D4 (black, 219 90CRI), love this light!
One question- Is the O-ring at the front of the light supposed to be forward of the glass lens (between the bezel and glass) or between the optic and the glass?
Photos in reviews look like it comes between glass and optic, would the D4 not be more waterproof if the o-ring was between the bezel and the glass?
Eg. From front to back:
Bezel > O-ring > Glass lens > TIR optic
VS
Bezel > Glass lens > O-ring > TIR optic
Mine came with the O-ring between the glass and the optic. When I took it apart to reflash, I moved it to put the O-ring in front of the glass. This seems to work fine, but requires a bit more care when tightening the bezel, and it can create oily-looking splotches where the glass touches the optic (at the 4 legs and center, not over any of the reflector cups, so it doesn’t affect the beam).
It’s really odd to me how you can take two glass lenses and wash them in soapy water, dry them off, you know they’re perfectly clean, right? And yet if you stack them and apply a slight pressure you will see that distortion or “oily” appearance between them. Another interesting test is to see how much light is blocked by stacking multiple lenses. Like, stack 10 and see how easy it is to read text under them. Makes it much easier to see that there are losses, multiple losses where lenses meet.
Try to get separation between surfaces if using a lens over an optic. Even if but a thread, get that bit of separation for clarity.
I don’t like leaving a plastic optic as the outer lens on a light. They get scratched easy, even from routine cleaning. And most of the spot optics have inverted cups at the lens surface, allowing dust and lint to collect. Much easier to keep a glass lens clean. Of course, that’s just my take on a daily carry problem…
Yep, same story as TK there. Just got the wrong info initially, and even ordered an extra 10622 when I picked up my first D4, thinking the stock optic was the 10621. When it arrived, it was clear that the stock and “extra” optic were both 10622 versions (just edited the post you quoted above). Sorry for any confusion!
