Thanks for the correction and good to know it wonāt melt haha. Iāll order one of these that you recommended today. At that size they might even fit a couple of my other lights like Toykeeper suggested.
Theyāre cheap, easily found at reputable dealers here in the US and worth the gamble.
I use my lights just about everyday, but Iām not using them for hours on end, so runtimes have never been āmy thingā and I have lights that do better in that regard.
I like smaller lights and bought the 18350 body with a few more of the last Aspire 18350s, but since I canāt run a clip on that config., I said screw it and Iāll probably never use it that way again.
Wonder what would happen if I try polishing my grainy blue D4 with Blue Magic metal polish. Would a little polish be enough to smooth out the texture? Would it destroy the anodizing?
I like the color, but that grainy texture feels like Iām holding a piece of chalk. Very uncomfortable.
We have guys here taking angle grinders to brand new lights, just to give them that āworn inā feel, so why not try sanding your brand new pimpy cyan D4 down with abrasive compounds?
Personally, I think youād end up with a woefully uneven finish, with bald spots here and there. Iām looking at mine right now and while you might get the 18650 body done with minimal screw-ups, I donāt think that youād get the head done even somewhat consistently.
Itās your light, knock yourself out. I suggest a nice āDremelā tool treatment.
Or thereās the way we used to put a little wear on new bluejean jackets.
Tie it to a string on your car bumper, and drag it down a gravel road til itās done.
If you really donāt like the anodizing that much, you could disassemble the light and dip in water with caustic soda for 30 minutes or so and youāll have no anodizing at all. Just bare aluminum, polish it out for a lustrous shine.
Just as a FYI, the anno if carried for a few months will start to rub off. Now I carry my green in the EDC rotation. So it gets a lot of use, go figure I live in the land of the midnight sun so winters are dark and ā¦ You get the idea.
Mine has shinny corners and edges from just being carried every day. The Chalk feeling is all gone and it is smooth. Give it a carry for a few months, it will smooth out. Then again, it may not, not everyone carries and uses in the same manor.
I have been thinking about getting a third one as I do like it that much. Green and black so far, may have to get a grey or blue oneā¦
Iāve done that with a number of lights. I use Greased Lightning to remove the anodizing and then steel wool, fine sandpaper and finally Blue Magic to polish it to a shine.
My lights polished in that manner look great. But Iām not a fan of the treatment for tiny high-powered lights. I find that without the anodizing, heat transfer to skin via conduction is much greater, while radiation to atmosphere is less. Basically if I removed the anodizing on the D4 I expect the head would become too hot to touch in seconds, making the light much less practical.
Then polish it and anodize it back to a color and smoothness you prefer.
āThats Rit āSunshine Orangeā from walmartā:Robot or human?. It was a 2AA black minimag before I cut it down to a 1AA and reanodized it.
Basically the smoother the finish before anodizing the smoother the finish after, but the anodizing tends to look candy colored.
I thought it turned out quite nice with the candy sunshine orange color. It still has some of the shiny aluminum bleeding back through.
I was planning to use mine for low and moderate lumens quite a bit, as well as max factor. So sad to hear it heats up within seconds and has no practical use at all.
Hugh,
I now own (4) of these lights, (2) Titanium w/the Cree XP-L HI 5D and black/smooth and Green/?chalky? in the Nichia 219C. I have no problems running them at low Lumens for a reasonable period, though on Turbo it does heat up rapidlyāI do believe the Titanium/Copper head examples can dissipate heat faster, but they are significantly more heavy. However w/(4) emitters thatās the nature of the beast. If heat is a concern, buy a big hunk of metal running a single Cree XP-L, etcāor the more reasonable BLF A6 or Convoy S2+ w/a single emitter for a cheap option @ around 1000 lumen.
Bottom line, this light is a bit of a showboat, but it was designed for that purpose. I donāt think that any other light can touch it for output/size ration @ $40. JMHO.
My reply was tongue in cheek when I was exhausted. I should have just left it alone. I responded to the insinuation that the light doesnāt function well at lower levels, which was just an emotional assessment.
