The GA is a good high capacity cell but can’t deliver maximum current’s like some others. It probably got low enough that it sagged below that 3.3V when you hit Turbo… by the time you got it out and checked it , all appeared well.
I’ve had flashlights that pull over 20A from a single cell before this one, I’ve run down a cell intentionally and then checked it at several points after the fact…. it’s amazing how much they bounce back when given a bit of rest! Hit em with load again though, and the fall is even faster than before, a lot faster! But if you’re trying to completely discharge a cell to hit LVP, it’s pretty tough to get the light to shut down. Takes much longer than I would have thought.
Just want to say thanks for all those that made this interface & light happen.
The UI is the best I’ve ever used. And its integration/tweaks in the D4 are superb imo.
Keep up the great work Hank and TK… and very informative review TK, Thanks
I have one more interpretation of my D4 and I’ll be done, but I have to wait for some bits and pieces to get here… :smiling_imp:
Edit: I should add, when you have tons of mod stuff like I do, especially after buying all Justin’s kit last year, it’s easy to not put a price on the things you already have and not feel bad about a modded light. But when you do something different and have to purchase those bits and pieces, a $40 light gets expensive very rapidly! All the work I’ve already done set aside, the final version will be an $80+ light. (Shhhhh! Not showing the paperwork to the Boss Lady…. )
It means the voltage went below 3.0 V, so it triggered low-voltage protection.
High-capacity cells like the GA tend to have more voltage sag under high load, so they won’t last long on turbo before LVP kicks in. IIRC it’s better at that than a NCR18650A or NCR18650B, but not as good as a 30Q or VTC5/6.
ToyKeeper, do you think Sony VTC5A could give this light another 200-300 lumens?
Dunno, I never tried one.
Dale got a few hundred more lumens with a 20700 cell and thicker wires, though.
I should buy a hand reamer so I can bore my tube out for 20700.
And when you heal from that, you could bore out the D4’s tube too!
As a recent GreenLight™ Laser PVP procedure patient….you guys are stressing me out. :person_facepalming:
Ha!
Might be less painful than a D4 accidentally switched on in a pocket though…
yeah, that might take precedence over an emergency run to the Loo
A what?
* looks up what that means *
Photoselective Vaporization of the Prostate???
Owwwwww……
Okay, chinooker wins the nut-roasting contest.
For your prize, I bestow upon you: One unobstructed urethral lumen.
And a memento of your experience.
It was just like that, right?
I think I can feel it all the way over here in California, and it doesn’t feel good.
My Dr.’s office keeps reminding me I’m over 50, I envision and balk… No Thanks, Trying to cut down!
Got my replacement xpl hi. Wow this thing gets hot!
Seems like the Sony vtc5 batteries work best in it
I’m enjoying my light, 25% practical/75% grins and giggles. A run of 20700 tubes with a little more metal than bored out tubes might be a nice addition. As is the tube and battery are half the heat sink.
How do you fit a 20700 in the D4?
Will the upcoming Tesla cell be 21700 or 20700 btw? Have they decided yet?
Still waiting for my two green D4s… I started a bad habit, collecting flashlights in pairs.
Twice the cost but “two is one and one is none” or something like that.
There is a new 21700 out, by Sanyo I believe it was, but constant current is low at under 5A.
I bored the tube on my D4 with a lathe. 4523 lumens is pretty ridiculous in this small light, I’m waiting for my short tube to arrive with some different emitters and I’ll be stepping it down to the 18350 and more reasonable current draw/output numbers.
It was all an experiment to see where the max was… it’s kinda what I do.
