The picture shows a desoldered red lead. From this scenario can anything catastrophic happen (eg cell short) if this loose lead touches something on the board like one of the adjacent components or the screw?
Can the vibrations created by strobing modes detach weak solder connections? When you play with certain frequencies you can easily feel the flashlight vibrating.
The picture would be helpful if it was in focus and showing the other side of the wire and also the solder pad on the MCPCB. As it is i’m not sure you can tell much other than, yep, not connected.
While i did manage to start a fire ( in a safe location) using a D4 it was more of a novelty as its much easier with matches/correct fire lighting equipment.
As for the D4V2, I was having trouble with the UI, i did ask about the thermal regulation settings, although never got as far as changing anything, when it was working it did appear that it doesnt ( didnt?) throttle down as fast or as sudden as the D4, which has a noticeable step down after about 10 seconds
D4v1 did its thermal adjustments suddenly, all at once. It’s easily visible.
D4v2 does thermal adjustments smoothly and gradually. The initial drop is usually still noticeable, but after it gets close to a sustainable level, the adjustments are usually too subtle to see by eye.
It always felt like/feels like the D4 is telling you off for letting it get too hot, Bumpf! - stepdown, “let me get too hot again and i will singe your fingers!!”
where as the D4v2 is more of a crafty but, reserved type of beast
Okay, but if the room temperature is set correctly, can the light be damaged if you set the max temperature as high as it will go? (IIRC, I think that is 70C.)
IMO, the light should protect itself. Otherwise, you have essentially a “suicide feature” programmed into the light as a valid setting. If it can’t operate at 70C, you shouldn’t be able to set it that high.
FWIW, the Narsil lights I have (like the Astrolux S43) seem to operate fine at 70C. Damn hot, for sure, but they haven’t melted down on me. (Internal temperature blinks out low 70’s when I shut off the light.)
I understand you don’t want to operate it at that temperature for long periods, because you risk heating up the battery beyond its 75C-80C safe operating temperature. But these lights heat up the head (where the thermostat is) far more than the body tube.
It does not really solve my problem as I explicitly like the momentary function (press and hold/release), but I am curious (and thanks nevertheless): How do I enable it, searching for “manual” in the FW3A PDF manual did only reveal an easter egg that was written with white font on the first page:
Does your car prevent you from driving with excessively worn brake pads? The motherboard for my computer won’t prevent me from applying too much voltage to my CPU when I overclock. I could find examples all day long. You accept the risk when you do those things.
People should take responsibility for their ignorance.
TK’s firmware does a good job preventing overheating issues but components may fail prematurely when exposed to excessive heat. You don’t accidentally change thermal settings, maybe it is possible but I surely never have and certainly it is almost impossible to set them so high without the knowledge of how to do it. It is too expensive and time consuming to calibrate the temp sensor in every flashlight. The majority of users appreciate the ability to set the thermal ceiling, because we know what we are doing and can use a IR thermometer to do so. The bottom line is don’t modify something unless you are willing to bear the risk.
With the factory reset function (which, unfortunately, wasn’t made until after D4V2 was produced):
Let the light settle to room temperature, ~21 C or so.
Loosen tailcap. Hold button, tighten tailcap, continue holding button for ~4 seconds.
Let go after the bright flash.
Without the factory reset function (which is how the first batch of D4V2 works):
Exit muggle mode, if you’re in it. Or exit momentary mode. Or exit lockout mode. Or whatever. Get back to regular “off” mode.
For each setting, navigate to that setting and change the value. Settings include:
Smooth ramp floor / ceiling.
Stepped ramp floor / ceiling / number of steps.
Smooth/stepped ramp toggle.
Turn off manual memory.
“Off” mode aux LED color and pattern.
“Lockout” mode aux LED color and pattern.
Beacon mode speed.
Which strobe-group mode is active?
Speed / brightness for each strobe-group mode.
Temperature sensor calibration.
Temperature limit.
Repeat for each setting in the list. May require looking up defaults in the source code (usually just the light-specific config file).
So… a complete reset to defaults is generally not recommended. There are several things to configure, and the details are different for each. Most people probably want to just identify which particular setting they want to change, and then change it.
Does anyone know a source of single 10621 optics in the UK (or EU)? Ive been wanting to try one out for a while but no one seems to be selling them in anything but large order quantities. MTN shipping is too expensive
