Flashlights are generally considered to be complete units that should never need updating. Most people do not buy a flashlight thinking they’ll need to update the drivers like you would on a PC.
A windows error on your PC is unlikely to cause physical damage to your computer or possibly start a fire. That’s not the case with the Muggle Mode bug.
The D4V2 requires special hardware and software to update the firmware and is clearly not designed to be serviced by the average consumer. Unlike a PC where you can download a patch during normal operation.
My conclusion is this bug is a product defect and it should be treated as such.
Perhaps you don’t have the bug firmware. Look at the bottom of the revised Anduril diagram. There are instructions there for doing a factory reset.which is a new feature that was just added to Anduril along with the bug fix. If your light resets to the default values, your reflash was successful and you shouldn’t have the muggle bug.
Usually, yes. The Emisars are not usual flashlights, though. Most people outside the flashlight community don't know they exist.
As it was said before these are clearly lights made for flashlight enthusiasts. If you can master the Anduril UI completely you can probably also do the firmware update IMHO.
Even inside the hobbyist community on BLF, none of us buy flashlights with the expectation that the firmware MUST be updated.
I suspect very few on this website have ever actually flashed updated firmware on any of their lights. I think flashing firmware is considered even on BLF to be an activity only for advanced flashlight modders.
Some good might come of this muggle mode bug though. As a result of the bug, more enthusiasts are likely to purchase the flashing hardware and give a shot to flashing their lights. This might open up modding to a whole new group of modders.
Only this automatic and manual memory was new to me. I am using anduril earlier than any factory flashlight. Just don’t read every update manual. But the bug still in this light and flashing is not working.
Ah I see , I’ve already seen them posts ,a. Video would be nice though.
With a quality cell like a 30Q I suppose the battery would be non deadly but I’m thinking if muggles had been running it with a fake or a cheap Chinese crapfire cell it may have exploded.
I ordered my first D4V2 (SST-20 4000K),directly from Hank (he sent the wrong one from what he agreed to send me after changing my order) and it has the muggle mode and the bug. I received the email from Hank and I'm just going to wait and see how this all turns out over the next few days.
In the mean time, I ordered a second D4V2 (XP-L HI, 5000K) from Mountain Electronics because I didn't want ro wait another 2-3 weeks. I received it today. It doesn't even have muggle mode (totally fine with me as I'd never use it anyway), as someone a few pages back also posted about their lights. This means I have a preproduction F/W in this light, according to TK's response earlier.
I wonder if there are any potential issues with the preproduction F/W or is the only difference the fact it doesn't have muggle mode and everything else is identical to the bug version? I'm guessing there is no way to tell how many preproduction F/W lights are out there, either?
It's too bad there isn't a way to display the F/W version by blinks with the light. How can the everyday average person know what version is loaded into their light? Maybe 8 or 9 clicks from off displays the F/W version or something similar. Just a thought.
I work on copiers for a living (in my 31st year) and the machines get F/W updates all the time BUT there is a way to see what version is currently installed so you know whether or not it needs updated in the first place.
I have noticed no other changes except for muggle mode, but I am sure TK would know. Looks like you will be flashing both. I had the same thought about blinking the version #.
I would test the thermal regulation , it might be the opposite to mugglesgate & start panicking if it feels heat , you’ll be safe though ,it will just step down to early ,you probly won’t notice unless you like to set it to 60*–70*C.
I wish some worst case tests would be done with this light… and hopefully end all the speculation and alarm about it capable of exploding or burning down a house.
So far none of this has been close to happen. For what i’ve read, the muggle bug happens with an already depleted cell which means that on turbo it will drain down very quickly and exhaust after a limited and decreasing heat dissipation. Which will cause damages to the light and it’s immediate surrounding… but very unlikely start a fire or explode. A cheap cell will do even less damage and certainly not go ballistic - there is no short involved remember. Although the D4 is known to be able to burn paper, you really have to want to do that. You need a thin sheet printed black to be very close to the optic and a fully charged capable high drain cell to achieve anything.
Did anybody really buy this light for it’s muggle mode in the first place?
It’s easy enough not to use it IMO.
The D4V2 is one of the most remarkable light i’ve seen so far. And it’s less then $50. I’m really happy with it.
Let’s get one thing straight. It does not require a depleted cell for the problem to arise. It just so happens that one of the early observations was with a cell in that condition. Some users have reported triggering it with cells at 3.8V. In my case the cell was at 3.5V after the episode of severely heating the light while unattended and after a few further experiments to confirm the issue. A VTC6 or 30Q as recommended has a lot of energy left at those voltages!
Perhaps, TK could explain why the muggle bug is less likely to be activated with a fully charged cell. I would think if the state of charge had anything to do with this, a fully charged cell would allow more on time and deliver more amps than a depleted one.
I tested one of my lights in muggle mode with a 30Q cell charged to 4.0 volts. After 30 min I stopped the test, because the light hadn’t turned on, and I had lost patience waiting for it to do so.
From what people on this forum have reported, the bug only occurs on cells below approximately 3.8 amps in muggle mode.
Supposedly it does not occur with full cells. At least that’s what people who have tried to replicate it on this forum have said.
Why that is so? … I have no idea. But if that is indeed the case, then the chances of fire are much reduced. The light won’t produce max output at only 3.8v
The muggle mode bug is probably never going to cause a D4 to explode.
When the bug occurs, the battery isn’t shorting. It’s simply that the light isn’t ramping down due to heat when it should. For the battery to explode without a short, the heat transferred through the battery tube to the body would have to be enough to cause it to catch fire. That simply isn’t the case. The heat may cause damage to the head. It may make the light too hot to hold. It may even warp the battery’s shrink wrap… but it should be far below what is needed to cause the cell to spontaneously combust.
