Thanks! That is where mine is. Somebody else,I think in another thread about this light, said there was two on the tube. The o-ring on mine that broke was a clear one, and that is the one that is on my tube. Maybe it was on the tail cap threads.
Yeah, I think they changed from white to clear. Mine did have another skinny o-ring on top of the clip to keep it from rotating. I took mine off and forgot. So there are two, but only one inside the light.
I have a feeling the odd problems I am getting (auto ramp down, and sudden brightness increasing) have something to do with this tube. I still have over three weeks to decide if I am going to keep this light. So far it is a bit quirky. In the long run, I am not so sure it will be a reliable light.
Can you please tell me where this resistor r1 is located? I’m ready to take it off, I can solder wires and single diodes, but I don’t know what it is))
One of these days, I’m going to have to take apart all my FW[x]A lights and update the firmware. It’s just a pain because they have to be unsoldered and resoldered, so I haven’t done it yet.
It’d be really helpful though, since Anduril 2 has a memory timer and auto-lock timer… both of which I’d use on FW-series lights.
But instead, I’ve mostly been using lights which are easier to update.
Flashing a driver is quite complicated and requires special tools. I never got into that myself.
To find the R1 resistor you have to unsolder the led wires and take the driver out. R1 is labeled on the pcb.
Ill try to add this picture showing the pads to the left of the R1 label.
It’s the same driver but different firmware.
In my opinion it would be best to flash the driver with the latest Anduril2 FW3A-219 firmware.
And while you’re at it you can add aux functionality.
Thanks, but it’s not really necessary. I’ll update them eventually, along with a bunch of other lights waiting for me to change or fix things. It just hasn’t been a priority.
