If you do that, what would you like to do with the dead soldier? I need the pill for an upgrade…
Or… You could try a driver upgrade on that one…?
IMNERHO, if you’re willing to commit to AA only, this seems like a Very Interesting Driver:
(I get the problem with links and lunch meat. If you’d go to the Fancyflashlights site and add “/goods.php?id=91” to the URL, or add “/goods.php?id=97” you can see why I want your dead one.)
These have a unique feature: in Low mode, they blink a signal, and at that signal if you power off, it comes back on in the other Group. One Group is H-M-L, one is H-M-L-Strobe-SOS. The first one’s mode spacing is thus:
100–25–5%
100–25–5% -Strobe-SOS
The second goes to 50% Medium:
100–50–5%
100–50–5%-Strobe-SOS
The downside for us, no 14500 support. I don’t think I’d miss it, but the mode choices might make that irrelevant.
I was considering another thread asking for comments on those two drivers. Would that be better than bringing it up here?
I own one (not sure which … CNQ…) and have a “Small Sun” copy of this F20 which is junk w/o work. The “Small Sun” has rat pus for a “pill”, driver, reflector AND emitter (in a pretty body with a clever name), hence where your pill would go if you threw it at me… Meanwhile I’m still hunting someone who can thread 18mm Al stock…
Your “accident” may have been serendipitous…
Not that there’s anything wrong with “another F20”!!
Managing the quoted text is tough, isn’t it? I’m new here, so it’s taking me some time to figure it out. Thanks for making me feel not so awkward.
I hate cheap lunch meat as much as the next guy, but the WWWeb site at fancyflashlights is easy to get. Just copy/paste the word fancyflashlights in your address bar & finish with < CTRL > < Enter > (meaning hold down < CTRL > while you hit < ENTER > )… Then after the “.com”, add the part I gave w/in the quotes.
I’m going to go check the forum rules for posting links, so hopefully this is the last time I have to dance around it.
I still don’t have a useful pill for my driver so I can’t speak to its function … yet.
I’m interested in knowing your thoughts about this.
MRsDNF, Ill still hold onto mine until a modded one is complete and that may be awhile. My aluminum pill is very very light. I was thinking about adding some pieces of copper wire and solder inside to beef it up if there is room to clear the driver.
As are all of mine. At least they’re metal!! Nebo and Small Sun (direct experience only) have yet to evolve that far…
I’ve already reassembled mine (it gets right dark ‘round here, come night!), but IFF you’re just trying to add cheap mass, I see you’re in the ’flood zone’, would a U.S. Nickel coin fit? You know our pennies aren’t Copper anymore…
What I was wondering is, if you add mass in the pill, isn’t that just Thermal Ballast? Wouldn’t the extra mass just retain and redistribute heat? I was thinking “The Idea” for an EDC was to get the LED’s power dissipated into the blood radiator of your hand…
Obviously there’s something to be said for slow transitions…?
I was begging for yours because I can’t find a source for just the pill. So I considered hiring a local machine shop to turn a couple for me. That begged the question of “cut off what?”, which led me to the idea of a big surface area with minimal mass (and a slot for easier disassembly!!!)… Which of course leads to a small piece of threaded pipe, which fires the machinist…
Sorry to wander off topic.
This is one of the main reasons I lurk here and pay attention to you guys and what you can take time to report.
Okay, I’m new here, but doesn’t that mean when you select the Mode you want, leave it on for some time, then turn it off, the light comes on the next time in the next mode after the mode which was on when you turned it off?? NOT the same mode???
That is beyond belief. Not that you found that fact!!! That it IS a fact. No wonder the vendors don’t post details! Why would anyone, who’d go through the trouble to design & manufacture this, think that was a good idea? Please tell me I’m wrong. That I haven’t wasted money and time. Or what IC it has so I can get a programmer!!! (I’ll look for myself, but I’ve never had much luck tracking down some of these component marks)
"Next Mode Memory" is really just a "no memory" driver which is not reset to the first mode quick enough (i.e. it stores the last mode used for too long). These are usually corrected with a resistor mod to shorten that reset time. It's not intentional programming.
