I should have said as well, the edc18650 has big enough slots to take 550 paracord and still tailstand, a lobster claw is a couple of dollars, once the driver arrives, this light will be going on an edc lanyard with my srm h03 pocket knife, both with lobster claws and a claw to attach to a belt loop, the lanyard will also be able to loop round my wrist so that it tightens if dropped (this is harder to explain than to achieve, I’d have to tie it and take a picture).
Seems like a headlamp would make a lot of sense in your work. If ever someone needed hands free light, I could see a medic needing it.
Hence the headstrap link, best of both worlds, I love my niteize strap and few head lamps will match a well driven c8.
Here’s a couple of charger suggestions from between rides.
The second is the nitecore I suggested above.
Thank you for all the posts and opinions. I will look into some of these additional options and try to make a decision.
I’m not opposed to increasing the budget if there are issues with some of these lights in terms of reliability. I’ve always been of the mind of buy the best and buy it once. That said, the best isn’t always the most expensive. There are also other items I plan on purchasing so I want to keep the budget in check. I actually came across this site researching a monster flashlight that a friend at work recently purchased. The more I read, the more options I came across and then became utterly confused.
The head light is a good idea but most of these lights would blind the patients. Most of us clip the pocket lights to the shoulder straps on our uniform for any hands free work. Plus this keeps the light slightly off center and hopefully out of the patients eyes.
Gords1001 made some really good suggestions.
If you look around some of the similar threads on here, you’ll see the XinTD come up again, and again… there’s a reason for that. It’s good. I’ll admit, I was hesitant to buy it because I didn’t like the “looks” of it as much as some of the other lights… but it’s a winner in every other way.
Also, question: Do you need a pocket clip on your smaller light? That may influence what people might suggest.
You can apparently add a solarforce clip to the edc if you make a spacer to make up the connection, a bent paper clip seems to work, if a little ghetto.
Personally, I remove pocket clips, they annoy the crap out of me, but if its useful….
As starter lights, I’d suggest a 501b with a P60 drop-in led bulb that relies on an XPG led for pocket carry. And either a C8 with XML led, or maybe an HD2010 XML for more throw. Should be able to do both lights for ~$45 max even getting better versions. Then add batteries from Kumabear and spend rest of the budget on a good charger. If you are fastidious about your gear and know your way around a DMM, then you might look into spare batts from laptop salvage, too. I’d make sure the lights or drop-ins you get have low voltage protection.
I suggest the 501b so that you can afford to lose it, and also because it is closer to the slimmer 2100 in size/feel than most other P60 drop-in capable lights. Also, being new to lights, you can change the drop-in if you find you want XML in both lights or just want to go for something custom programmed - something you can’t do with many of the smaller pocket lights.
The 2nd and larger light is harder to fill at the budget level, so getting something a lot of people have and like seems the best way to start out with your first buy.
What determines the distance and how compact the beam of light is? I’m assuming it’s the reflective cone at the head of the flashlight and it’s rated lumen? I see several boasting 2K and 3K lumen and from a novice it sounds like bigger is better. However, there seem to be several in the same category and price point that come in at 750 to 1K lumen and I’ve read reviews on some and they seem to out perform others with higher numbers. Is this obtained from simply a better product or are some companies faking their numbers or am I just looking at this the wrong way.
Also, can someone explain the differences in the batteries, protected vs unprotected.
Thanks again.
Also, I don’t have all of the technical jargon down, but I assume I’m referring to the “throwers”
1 # is your best idea to date ..Not that model but a single 18650 straight tube light that has an xml ,,it will be pocketable in cargo pants . it's pretty small compared to what you think a flashlight should be ..
Both 2 and 4 have some pretty serious issues in my humble opinion . i think they represent something they aren't
A. I think a noob thinks a multi cell is "twice as good " or twice as bright " twice as big etc or even that it runs twice as long ..All of those are wrong
Multi cell lights first off are 10 times more dangerous /// i'm not really scared since i know how to run a muliti battery light and have what it takes to do it correctly ..But part of that selling you on the fear is to generally discourage you from these lights anyway ..If you're really a noob then almost any well driven 18650 xml light is going to be so bright that 90% of the time you're dropping it down to a much more reasonable level of light ... secondly the multi emitter lights are hugely floody and at least to me that's really a poor definition of what a flashlight really is ./Thirdly they suck down so much power that they A . are dangerous and B. don't add to runtime only add lumens C. a single cell light does about 80% of what a double cell light does ..and overall runtime isn't an issue if you buy decent batteries ..lastly the money spent on a gimmicky cheap supposedly brighter light is money wasted when it could be better spent on really important , not terribly obvious to a noob , but highly appreciated aspects of what better lights include ... Better threads , higher pwm , nicer anodizing ,knurling , thickness and quality of materials ,tint , binning of emitter ,driver ,quality of clicky ,glass? coated or not ,reflector etc etc etc ....
Let me give you a few suggestions .. I think what you want is a unique-fire 2100 just made a bit better ..Lights like the N-light st-50or a roche
http://www.fancyflashlights.com/goods.php?id=39
i'd highly suggest the Neutral white lights if you have any opportunity to do so like this light offers it for 1$ extra .. that's a pure gift .. for much better color rendering / less washout etc ..Don't worry about not buying CW emitters ..99% of all lights come cw like it or not .. you'll never be lacking for cw emitters
http://www.fancyflashlights.com/goods.php?id=329
http://www.fancyflashlights.com/goods.php?id=142
http://www.fancyflashlights.com/goods.php?id=27
and then i'd buy a
https://budgetlightforum.com/t/-/12633
xintd c-8....again in neutral ...and on anything I bought I'd avoid the strobes for the same reason.. craepy light s with crappy tints and stupid modes will come to you like moths to a flame .. don't purposefully seek them out .
Charger is easy I'd buy aSysmax intellicharger V2 about 20$+ cuz it will charge nimh and lithium iopn and almost any sixe battery made .. very usefulll smart purchase ..if you have to buy a litium ion only charger I'd buy a tr0001 i think light castles had them for 8$ ..
https://budgetlightforum.com/t/-/8112 much more universal ,, it will almost dertainly keep you from buying a nother nimh charger too or a charger for 26650 batteries
18650 batteries in the US has to go to Kumabear
https://budgetlightforum.com/t/-/11558
I'm not a huge fan for buying the latest and greatest highest mah batteries .. better bang for your buck is probably 2600 mah... that said If i were you i'd probably buy a 3400 a 3100 a couple 2600's and a 2250..Probably a little over 40$ < maybe one of the smarter places to invest in flashlights ..cheap batteries is like taking a leak in your gastank and wondering why the mileage and power sucks on your car .
I may be a little over budget but doubt that anything I've said will lead you too far astray ..
welcome to Budget light forum
Thanks Boaz, and props on your typing skills….that’s a lot to drop in 4 mins ;). You have my attention in regards to safety. Now I’m not exactly sure if your referring to these lights blowing up in your hand or sitting in the cab of my truck and starting a fire, but I’m not interested in experiencing either.
Are the single cell lights you listed going to be able to search a large area? I need to be able to put a lot of light down range and up in the trees. It will need to make things visible at 200 yds or so. I remember reading that the multi cells that were not inline were safer and I read a decent review of one of the small sun lights and I believe it uses that configuration on the battery.
The beam is determined by the LED design and the reflector (or optic for TIR). Larger diameter reflector generally shifts any beam toward more throw. XMLs are generally a lot of floody light without a big reflector (in a C8 you get a much better balance of throw and flood than seen in most smaller reflectors), XPG are a good balance of throw and spill in the P60 sized lights (why I recommended it for you - preferably a XPG2), and XRE are generally narrow beams without a lot of spill.
Very simply, unprotected batteries are dumb cells (like those used in laptop battery packs) that can be over-discharged if the light does not have good electronics like the laptop pack has. This is very bad. Protected batteries have a little PCB board at the bottom of the battery to limit discharge (and sometimes more) and are thus slightly longer than unprotected. Length can make a difference in some lights, generally not a big problem if the light has springs at both ends (which I strongly prefer), but that can add a bit of length.
Oh, they’re only $5-8 so I would add a Sipik SK68 or clone using AA sized eneloop or duraloop NiMHs to your wish list. They’re not lightweight, but they are versatile with the zoom or flood to throw feature and their aspheric lens. Example:
There are single and 3 mode versions - lots of threads and recommendations on BLF.
Note that it may help you look at chargers that do both lithiums and NiMHs. Or you may want separate chargers to have more bays.
That’s the extension-capable genuine TrustFire X8 that is. Overall performance-wise no real contest IMO, and about the same or less money. 8)
Just sayin’…………………………………………
Have to take your word. The input specs suggest it might not be a low cutoff for a single cell, though.
EDIT: The X8 seems to be more comparable to the T6, which seems to be the 2 cell version of the C8.
More importantly, if the OP wants a 2nd light to be more thrower, he probably would be better off with a larger reflector like the HD2010 or the newly popular Small Sun (08) with the same size reflector at about the same price as the quality host XinTD.
Careful of the lows on your lights if you are going to use them for pupil checks.
As a night respiratory therapist in boston i currently carry a shiningbeam caveman, the outputs on high are probably not enough for you but in a hospital setting the low is good for pupil checks and med. and high enough for most other work.
also i can get AA batteries at work.
I have previously carried a:
-Trustfire R5-A3 ( great, about 15usd, AA, low is too bright for work and strobe is uneeded, but have several in my bug out gear and home, have had them quit on me after 3ft drop)
- Nitecore D-10 ( one of my great loves, out of production, stopped carrying because i was afraid i would lose it and be unable to replace, AA)
- Shiningbeam S-mini ( prefer the XP-G over the XM-L, better run time and more realistic color, but low is still too bright to shine in someones eyes, on my hip almost constantly outside work, not cheap, 34usd, well made, survived several drops onto hospital linoleum)
-Solarforce L2P ( with the correct drop-in from forum member E1320 this could be the ultimate but i have not had the expendble cash to find a P60 drop in with a low enough low to routinely check pupils)
-Ultrafire RL-168 ( huge favorite until they raised the cost to almost 30usd, now three-mode compared to the older better two-mode, comfortable low and high, AA, memory, my SICU RN wife carries at work, she has my last one)
- BLF special edition TANK 007 ( too small for my ham-like hands, hate twistys, gave to another SICU RN who carries it at work, AA)
Random thoughts:
- dont scrimp on batteries. stick to protected for work. good ones hold charge and 2600’s seem to be fine if you are changing them on a regular basis. (which you should) I have been happy with AW’s (overpriced) and International Outdoors.
-single cell lights, if you can help it. simple, outputs can be remarkable (Ultrafire UF-980L is a wonder) and you can lend to others for use without explanation’
- holsters. can be uncomfortable or problematic to use, specifically if you sit down and get up a lot, look around there are many different kind and it takes a while to find your preferred carry. (for me, left hip, rear, open top, lens up)
Do you know what the lumen range is you want? 8-10 lumens seems to be plenty high enough - that’s mid-level on my T10 and it is bright without being uncomfortably bright. Firefly is too low. If 3 - 5 is enough, that might be better for the lowest low. I tried 60 lumens and found that pretty uncomfortable.
If you know your target lumens for checking pupils, E1320 can probably build a drop-in with a mode designed for the approximate level you would like. You can also have a lower low and highs for other light uses, or just keep it simple with fewer modes. Just send him a PM for details if you want to avoid a bit of trial and error.
oh no, i know he CAN build what i want.
i just am finishing up a long slog of debt and actually about to pay off my last credit card this week. then, except for my mortgage i will be completely debt-free. i have little extra funds (with a girl in college) for my extraneous hobbies.
also, i believe E1320 has been unwell and i would rather not burden him while recovering. there will be time enough once he is better.
That ain’t nothing, you should see scaru type!
I’m sort of an outlier on BLF as I don’t use 18650 lights, so I don’t have an opinion as to what you should get. I do, however, appreciate the service you provide your community and would like to say, “Welcome to BLF”.
I've got a few wall shots for the FandyFire G36 you are looking at in LightsCastle.com. I've also included a quick shot of the flashlight body. There is a mouse pad you can use in comparison for it. Also, this flashlight is going on sale soon at LightsCastle, we're releasing a landing page soon with the new price for this light.
FandyFire G36
Low
Medium
High
peace,
Josh
