The Sanyo NCR18650GA has a 3.6V nominal rating and if you calculate the average voltage during a 0.2C discharge .my guess would be that the result is very close to 3.6V.
Because I only discharge to 2.8V I could not verify that. The average voltage I got at 0.5A was about 3.65V and 3.63V at 1A (0.2C is 0.67A).
Of course, but i was referring to the discharge graphs.
They show a steep voltage decline from 4.2 to 4.0 Volts, which is not because of the internal resistance, because then it would be immediate, not a decline over a short amount of time.
Or am i wrong?
Those graphs didn’t ‘speak to me’ earlier, but now i see (better).
Still, there’s a ‘knee’ there, but it’s around 4.1 Volts.
I’m not sure about the recovery after charging cuts off, but i usually measure 4.15 V on a freshly charged cell, but that could be my charger…
This has to sink in yet somehow… (in my mind that is…)
But thanks for explaining so far.
Well, I guess that is your answer. You could get a basic version of the Imax and flash it, I keep thinking I should order another one while I can get them just to have around.
Full control for one thing, you can also calibrate it to be exact, much more accurate, the ability to use external “probe” to sense actual voltage after the wire voltage drop allowing for internal resistant measurements that actually work and better charging. Plus just general improvements.
It is not a must have but if you like full control over all the details of your batteries charging, then it is lightyears better.
If you guys are curious to know - I had charged the batteries from my old laptop to only 4.1v out of caution many days ago. Today I decided I wanted 4.2 or flames. Each cell took another 110 mAh.
