I just watched the video and it's a pretty cool charger for nimh and nicad's.
Yes it is man......what i like about it i can charge a pack at 1.5-2amps and my batt pack just gets warm, unlike the superbrain which misses termination a lot, still not a bad charger since its old just like me. lol
Well old just means that they are made better and tougher than these newer ones.
Nope, old is old...lol.
I'm not that desperate for CC/CV that I'm willing to pay for the Pila or a hobby charger but would prefer something close. Since some of the HXY were evidentally CC/CV I got interested for a while but based on my research it doesn't sound promising I'll get one which does do CC/CV so I'll probably just stick with the Shekor which seems to be close, particularly if you do the spring mod (well these ones could change too but the reports are from fairly recent batches and from KD ones so it looks more promising, what happens with next years batch probably won't matter to me). Hopefully I don't regret the 9 hours or so wait ;-)
Of course knowing my luck a few days after mine has shipped whatever I end up getting I'll read a report that the WF-188 is a super charger which does CC/CV for li-ion and LiFePO4 and with an excellent NiMH charging profile as well :-P
Anyway your hobby charger isn't old, it's a 'senior citizen'
Now that was a good one......yes your right about the chargers....i kind of like the 188, and for the price you might want to get one as well.
I don't know if I was the only one but I was thinking the WF-188 does NiMH like some others because it mentions AA. Looking more closely it clearly does not, no mention of 1.2V or NiMH or anything. I guess by AA they mean 10450 and by D they mean 32600. Ooops :-P
Some better pictures here which actually show the switches properly http://www.szwholesale.com/ultrafire-rapid-charger-32v37v-lithium-batteries-wf188-p-3715.html (I could only make out one switch in the KD pictures)
Hi anduril
Why don't you try the ultrafire WF-188, only cost $17.92 or $15.05 does all batteries
AA,CR123A,16340,18500,18650,25500,32600 D type,etc.
http://www.qualitychinagoods.com/ultrafire-rapid-charger-32v37v-lithium-batteries-wf188-p-1710.html
http://www.kaidomain.com/ProductDetails.aspx?ProductId=10638
By AA there referring to 14500's and similar size cells, in the description it says that it cannot charge 18650's flattops i wonder why because when you look a the chargers postive side it seems to protrude.
Thanks to everyone for posting all the information and links.
Just about to step up to Li-Ions and buy some 18650s, 14500s and 16340s, will probably go for the Trustfire Flames just now and maybe AWs later.
Have also just split an old laptop battery and found 9 17670s.
My 2 top charger choices are the Shekor and Ultrafire WF-188, leaning to the latter due to features and shorter 18650 charge time if I understand correctly.
I might just wait a bit to see if someone posts a review of the WF-188 and to give time for more stores to stock it so the price stabilises.
Cheers,
Gary
Dang if you lived in the states i would love to trade you a couple of 18650 sanyos for one of those.
Heh to be honest you’re probably better off that I don’t live over there anymore, I’m not sure how much more life the 17670s have left in them as they’re from a very old laptop.
Seemed to charge up ok in the laptop but will wait till I have a proper charger before I split them.
Make sure to check the voltage of each cell before you charge them, and disgard and ones that are below 3.2volts. Since the cells are old make sure when you charge them to please keep an eye on them since there unprotected and check the voltages of each cell when they come off the charger, an ideal charge would be around 4.15 and over but no more then 4.2volts.
Thanks for the advice Al.
I’ve got a lot of reading up before I attempt to split the battery pack.
Heres a good read, this was put up by my buddy Craig..... http://www.candlepowerforums.com/vb/showthread.php?t=246699 Just make sure your able to take them apart if you can outside of your home, so this way if something happens like swelling or a terrorist cell your able to chuck the pack. Its easy just as long as you take your time and make sure not to make a connection with your tool. This is a good way to save money and all it takes is a little bit of your time.
Sorry Al, forgot to thank you for the link, very useful.
Will be looking into some sort of fireproof material to sit the batteries on when charging and possibly a very larger pot for storage if I get paranoid.
I stumbled on to a CPF thread about a TK Monster turning into a pipe bomb due to faulty/neglected cells.
I think I'll stick to single cell Li-Ion flashlights for now.
At least until I find that I have too many fingers and can afford to lose a couple.
But that was a marginally safe device at the best of times - I mean, a 250W bulb (overdriven) is pushing things a bit on thermal grounds and it is clear that the guy who got it didn't really know what he was doing. The cells were expected to produce about eight amps at high temperatures. This is not going to be good for any cell. What's worse is that they were much safer cells - basically the same formulation at the AW IMR cells. There's quite a bit of discussion here.
http://flashlightnews.net/forum/index.php?topic=2569.0
Really, multi cell lithium lights do require a bit of sense and a voltmeter. And tossing any cell that doesn't recover to about 2.8V under no load.
The Solarforce L1200 explosion I mentioned in http://budgetlightforum.cz.cc/node/318 is another example of what can go wrong. That one is less extreme, well I didn't know much about the light but a quick search shows it uses a 30W bulb so perhaps about 2.5A per cell (there are 3 of them). The explosion wasn't as catastrophic but it did happen in the persons hand with the resulting consequences (although he was fortunate and didn't lose his fingers). It's interesting many of these cases seem to involve incandescent bulbs although whether that's just because of the higher power usage and heat output, more common use of multiple cells, other factors or just randomness (we've only discussed two cases).
Oh and both involve WF-139 chargers too! These seem to have been owned for a while so I do wonder if they terminated properly, I think this was discussed but I don't know if it was ever answered.
Another thing that has been discussed somewhat in the CPF thread and probably other places and occured to me even before I read about any exploding flashlight, many flashlights with li-ion batteries aim to be strong, water proof and likewise people do screw things on tight, upgrade the o-rings etc both for good contact and to improve water-proofing. But this is problematic when the batteries go badly wrong since you now do almost have the workings of a pipe bomb as the OP suggested.
Vent outlets are of course a common design feature of devices using li-ion batteries that torches tend to lack. I don't know for sure how much it would help but it seems to be some sort of vent outlets may reduce the chances of serious injury from batteries gone wrong inside a flashlight. While it would likely reduce water-proofing particularly if you're talking about things like diving, I would think you can use some sort of rubber or whatever covers/attachment which will still provide decent water-resistance. These don't even have to be designed to be reattachable for obvious reasons. It will raise costs of course but surprisingly few (well I'm not aware of any but I never really searched) seem to have done it even among the high end.
Edit: Actually I see the TK Monster does have a vent of sorts but this obviously didn't help much and the discussion in the thread suggest a better vent may not have either.
I've been doing some more research on hobby chargers and it seems the best cheap one is probably the Turnigy Accucel-6. Extensive discussion http://www.rcgroups.com/forums/showthread.php?t=886698 here. You can get it for $22.99+$12.12 airmail shipping (for most places I think) from HK*2 (HobbyKing's Hong Kong office :-P) http://www.hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=7028 which ironically is cheaper then the Dealextreme stuff. Many of the these hobby chargers are very similar, from what I've read the Accucel was based on the IMAx B6. Many others then copied one or the other but the Accucel appears to be one of the decent variants and really has CE and not the 'China Export' variety (also evidentally RoHS but I don't get how that guarantees the safety of the product, unless your opening it up maybe). It also uses decent components, MOSFETs are properly heatsinked, generally is well calibrated, balance is fairly balanced and has a fan. Does need a PSU though and despite some confusing comments in one of the reviews the USB port doesn't work by default http://www.rcgroups.com/forums/showthread.php?t=1046318. Ironically Hobbyking themselves also have several other slightly cheaper clones even though they warn you about clones in their Accucel product page.
Damn you sir!
It took me long enough to narrow my choice down to 2 possibilities and now you complicate matters by making me aware of 3 more decent looking chargers, albeit more complicated and more expensive.
If I have read the thread you posted correctly the one you mentioned Turnigy Accucel-6 and the HobbyKing ECO6 look to have similar internals but the ECO6 is in a cheaper case and has external connectors and the seemingly new HobbyKing Variable 6S also seems very good.
Probably more features than I'd need but the price makes them very tempting.
