I’m sure it’s been brought up a lot already, but it is bizarre that you cannot see the other participants in the private messages. In my INBOX, I see my own name and that’s it, for many of my PMs. Useless.
Yes, it’s an unfortunate consequence of using a non-standard forum theme which really cleans up some aspects of the /latest list, but it uses that same code for the private messages list and that paradigm doesn’t work there.
It should be noted that you can see the participants inside the private messages:
Do you find this to be an acceptable situation? The PM system is like, dysfunctional.
I’m trying to solicit judges for the OL contest and I can’t tell which PM goes to who. I suppose I’ll have to put their name in the message title in order to make sense of it.
What I can do for now is that I enabled the default Discourse theme, it’s available now as Discourse-default in the theme selector. I haven’t fully tested everything with it, but it should be good enough to at least switch one browser tab/window to it and use that one for PMs, and then keep your normal theme preferences for other BLF activity in other tabs/windows.
FWIW, I took a look at the raw html the site generates when my themes are applied, and the names and avatars aren’t actually present in the markup as far as I can tell. So there’s nothing I can do with CSS to add it.
So for now the only option is to use the “Discourse-default” theme to see who a message was sent to… or open each message individually to find out.
I have some other stuff to fix up though, due to underlying changes in the site… so I hope to upload a theme update soon.
Thanks @Hoop for your patience, and as always thanks to @ToyKeeper for the technical help.
I see this in the posters map with the Discourse-default theme in /my/messages , the data-user-card value can’t be displayed with CSS even when not mouseover?
Printing the usernames in text would be Improvement 2.0, as for implementing the most basic improvement of showing the participants in a PM I have two options that are almost working via handlebar template overrides:
Show the td.posters.topic-list-data column from the Discourse default theme while using the BLF Default theme only inside the PM list. I have this basically working, but I’m having trouble modifying the column header only for the PM view, so the PM list is skewed to one side with the addition of the posters column.
Add the td.posters.topic-list-data column to both /my/messages and /latest. This would be easier to implement, and some might appreciate the overview of frequent posters in public threads, whereas others might see it as clutter.
Yes, the td.posters.topic-list-data field doesn’t exist in the HTML I’m receiving. The list items have td.main-link, td.num post-map posts, and td.last-post. So the server would need to send additional markup before the stylesheet can display it.
OK, I think I have the most basic improvement implemented in the default BLF Theme (and I disabled the Discourse default one again). You might need to reload your BLF browser tab to see the changes:
I would appreciate any CSS tips that @ToyKeeper might suggest to make it sacrifice the Last Post column when the screen width is reduced instead of shrinking the Participants column to just 1 avatar. Also, I didn’t enable this improvement yet for your themes because the new column needs a bit of padding to work with your modifications.
