Well damn.
You learn something new every day.
Remember when even the USB A to C cables were problematic because the manufacturers didn’t put in the necessary resistor? Fun times.
In case it helps at all, the only light I’ve heard of which probably does work with a C-to-C cable is the Fenix PD36R. And I haven’t even been able to 100% confirm if it works. But based on the info I’ve found, it sounds like it probably does.
Otherwise, it seems to be the norm that lights require an A-to-C cable for charging.
I sent an email to Olight asking about the $300 light mentioned above that misbehaves like this. I’m curious what they say.
I can see a $25 light design skimping on $0.60 of “optional” parts… but a $279 X7R?
Do we have a contact at Astrolux I can ask about their lights?
I kind of feel like the whole “USB-C” thing on flashlights is a joke - the benefit of USB-C over all the other variants of USB is the ability for them to dynamically work out between the devices which device needs charging and which can be used to charge from, for example if I plug my phone into my laptop and the phone gets charged or if I plug my phone into my battery pack, the phone gets charged - but plugging the battery pack into the laptop, the laptop gets charged, all with the same cable.
That’s useful!
Being able to charge my flashlight from my battery pack or charge my phone from my flashlight, with the same cable, that’s also useful.
The way it’s implemented on flashlights is nothing more than a very mild convenience in it having the same connector - especially useless if the connector it needs (USB-A to USB-C) is one of the less common types available. It’d actually be much easier to find a USB-A to USB Mini or Micro cable.
So the whole things a bit of a sham…
LT1
Apple iPhone Pro 18W USB-C charger - FAIL
Anker Premium 60W 5-Port Desktop Charger with One 30W Power Delivery Port - FAIL
Anker PowerCore 10000 PD Redux Power Bank - FAIL
ZGGCD Universal charger with USB-C - FAIL
Monoprice Select Plus USB Power Bank - Success!
I have 2 bike lights with USB-C ports:
- Cycliq Fly 12 CE - charges via C-C, but not all A-C cables (from memory)
- Cycliq Fly 6 CE - charges via all A-C cables I’ve tried, not C-C
USB-C chargers tested:
- Plugable USB Type-C Power Delivery 60W Power Supply
- Google Pixelbook 45W charger
The Relic XR2 I recently got will charge A-C or C-C and charge other devices C-C. Check out my posts for my initial review video and more info.
The Noctigon K1 charges fine from an Apple MacBook USB-C charger. Also an iPad charges it too fine, useful in an emergency I guess.
Wuben T70 - fail ( released 12/2018)
Nitecore Minix - pass!( modern, just released 2021) (though it is very small, high current not used or needed)
Sofirn SC21 - PASS
It charges just fine using the USB-C chargers that came with my Samsung phone and Lenovo Laptop.
Geeeee wiz.
For some reason this thread reminds me of this thread…… :laughing:
PS. Sorry, Amish. Not hijacking ya. I just couldn’t help myself.
This is a big headache for me as well.
I’m in the process replacing all my cables w/ C - C and C - Lightning, thus eliminating A ports all together. However I found a ton of made-in-China (no prejudices, most of mine just happen to be made in China) small electronics w/ C-inputs only support A - C.
If you ask the manufacture of most lights w/ C-ports they’ll tell you they only support A - C charging, especially smaller brands.
*On The Road M4 - Fail
*Nitecore T4K - Pass
I routinely charge my Acebeam EC65 from an early Anker 12V charger having one C and 3 A outputs, using the C port to do it. The cable is a several-years-old one from Home Depot. From this thread it sounds like it’s the earliness of the Anker USB C charger that makes this possible, maybe combined with having randomly stumbled on a compatible cable. Ugh!!!
