+1
I give in… can I change my CW to NW too please? I am No. 212
I am waiting a definitive response on this. ![]()
The lens has anti reflective coating on both sides.
The soldering quality on led star is good. The soldering points on switch are a bit ugly but will be fine in production version. Also the boreholes in the pill.
I’ll do.
Sample looks great (heavy sigh). Can you please ADD 1 more CW for a total of 2 CW. I am #140 on the list. I would also be interested in extra pills if they become available.
Cyberescudo, could you add a CW for me, that way i’ll have both, thx !
Please put me down for one more NW, I am down for one already at #165, so this will be a second one (1x cw (old order) + 1x nw(new order)).
Thank you and great work!
Please put me down for 1 NW, thanks.
Well I come to this topic just to look at this pic
Wow, just wow
Hi Cyberescudo!
The final flashlight seems to be incredible. Good job!
Could you please confirm us, if we can use flat top batteries on the Cometa final version?
If it has any kind of ring on the positive side to avoid reverse polarity, then flat top batteries will not work.
Thanks in advance!
Ciao
well done sample the tail light look right on this one both sides leds and less bright
put me on the list for one NW
You can see springs on driver and tail
Flat should work
Thanks for the answer, h2o.
Where did you get this information, only personal experience or did you read it anywhere?
From my experience, I agree with you, in most conditions, CW lights throw better than NW lights with the same led & power, only in fog or snow the NW throws better due to reflection and the tint, you can see far more clear with less light reflection. In fact, fog lights from old cars where yellow, to avoid reflection. There are also night googles, which are yellow, to avoid the reflection of lights coming from other cars headlights going to the opposite direction.
But I read some different opinions in different forums, and I only wanted to have it clear, if this is up to personal experiences, or there is any cientific study that support this.
As you say, if CW measures more lumens than same led in NW, there is a difference. Call it sugestion or stupidity, sometimes it is measurable with machines, but humans cannot find any difference on them (like happens in loudspeaker cables, some people say they feel differences between cables of silver and cables of standard copper, and oxigen free copper, but the truth is later, on a blind test, they cannot feel this difference with their own ears, even if the difference is measurable with good measuring equipment).
In any case, the Cometa will be amazing, even in CW or NW!
Flat should work
Sorry, I miss that. Thanks for the clarification!
please add me to the list for a NW
Add one NW to #215 please.
The difference is not like that in speaker cables of equal gauge where one is special brand and other is not. In this case both cables would be same gauge with the same # of strands and same % O2 free. It is something you will notice. Best way is to order two lights, one of each tint from same manufacturing run.
Also, of note… the same spec LED from from different factory runs can be hugely different. If you are sent a special sample from major designer, it may be able to take 10x the current, and have better response along most graphs you plot…. just a side bar; only benefit here would be that everyone might get a chip off a hand picked reel. …although some samples are so good they can’t even let you get a whole reel.
I even have considered changing to CW after doing this a few weeks back. Without the side by side, I think NW is nice. I have some 9X+CRI from major brand hooked up at home AC circuit, and the CRI is nice, but too yellow. CRI is more important than tint, IMO—but these might be good fog lights with proper optics.
Peak throw in fog, IDK get the NW. Any side by side with these two BINs and same cells you will (and I bet just about anyone) notice apparent brightness difference. The tint will be more noticeable too, when side by side.
On the science of why, it has to due with our sensitivity to green. For this reason some cameras would use use CMOS with RGGB sensors, an extra green produced results in double blind tests that surveyees found to look better.
Is there any chance this light could be available in Warm White (circa 3000k) ? ![]()
Guys as i’ll have both NW and CW, rest assured i’ll do beamshots and throw measurments (as well as amp draw), and also compare to my modded Brynite B158
Unfortunately no :cry:
“Extra green”? Please not in flashlights, at least not for me. :confounded:
